55 F250 Rear Suspension Questions
I was looking closer at my rear suspension and it seems to be different than others I have seen. I briefly looked for other examples, but nothing seemed to match quite like mine. Could you enlighten me on this suspension? I figure to leave it like it is unless there are problems. By the way the first owner had a Knapheide bed installed in it. (never met him and the previous owner passed away)
I can never imagine the bumper ever getting down to the axle.
That upper 6 springs and the 2 upper stack stops on the frame were added later along with the super long U bolts .. i have a 55 F250 so i know just what been added to yours. That plate on the very top of the stack that the Ubolt top bend rides in should be on top of the orig lower stack. And much shorter U bolts.
I was told that when they loaded it with grain that they would make this truck into a dump bed by attaching a chain to the front and lifting the truck with a tractor to empty the bed.
Of course I will never put that much load on this truck, so I need to ponder whether to remove the extra support....I a long way from having to make that decision though...
Don't know if Ford offered overload springs back then, but they are simalar to the overloads offered on latter trucks. My 96 has factory overloads simalar to those. They overload brackets look like a factory item or maybe an aftermarket set up...
Paul
Paul
New trucks use a very close 2 stage design like that setup but a far softer base stack to give a soft ride when unloaded. That looks like a stock F250 bottom stack. That upper set won't come into play till you have 3/4 of a ton on that puppy. I'd leave them if you plan on carrying some 3 ton loads.
I have a 54 F250 with the overload springs on it. It has the express box. I always assumed they were original. Many years ago, I before I tore it apart for some upgrades I went to a local quarry and pick up a "little" load of rock. It was only a couple of miles from home and I would go slow anyway. I ended up with almost 2 tons on it. That was a scary trip.
I'll have to look, but if I remember right the pics here look like mine.
Harrier
07-29-2013 10:16 AM
Harrier
18
07-23-2013 07:06 AM
Harrier
12-06-2010 01:05 PM
