460 weak performance
Old 10-06-2010, 12:31 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
F-250 WARHORSE is offline
as I have previously mentioned, my 460 is VERY, VERY sick. The cause isn't found yet, might be pistons, might be cam might be ? However, the engine loses vaccum as the RPM increases, like it has a plugged exhaust. Noone seems to have ever seen these symptoms before and We can't pinpoint the cause. Any suggestions?
Old 10-06-2010, 02:31 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
well have you verified that you DONT have a plugged exhaust?
Old 10-06-2010, 05:47 PM
Victor L's Avatar
Victor L
Victor L is offline
The best mechanic in town replaced an engine just to have the new one do the same thing. I was walking behind the car, while the owner was watching the mechanic try to figure out the problem, and noticed the exhaust crammed with red clay mud. Pointed it out, and the mechanic unplugged the exhaust, and the car ran fine.
Old 10-06-2010, 05:49 PM
Victor L's Avatar
Victor L
Victor L is offline
Does it have a catalytic converter ?
Old 10-07-2010, 07:41 AM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
I guess this means you still haven't found the problem. The loosing vacuum as you increase rpm sounds like either exhaust or no spark advance. It's too bad you are around 2000 miles from me as I would really like to look at it for you.
Old 10-07-2010, 05:05 PM
F-250 WARHORSE
The engine does this with the exhaust un corked at the manifolds, so I doubt that the exhaust is plugged. Same symptoms with the exhaust hooked up as with it unhooked. As for the spark advance, this occurs with the timing light going all the way to over 40* at about 2500 rpm with the Mr gasket dizzy recurve kit. Thanks for the input so far this seems to be a never ending battle so far. This is the third time that i've asked about opinions on the problem, and am still looking but with perseverence and peoples input from similar problems, I will find it eventually. The builder is thinking that it might be a bad camshaft, we have verified cam timing, tried different distributors, and so on. I will try some L&L headers and fool with the carb a bit, but I think the engine is going to have to come out and be tore down this winter. Thanks guys, I will keep looking for the problem.
Old 10-07-2010, 06:09 PM
bobbyjo9's Avatar
bobbyjo9
bobbyjo9 is offline
Have you cked for vacuum at the pcv? If your loosing it on top of the piston maybe it will show on the bottom through the pcv valve? Also what reading are you getting at idle? is the needle steady?
Old 10-07-2010, 06:36 PM
F-250 WARHORSE
steady needle. by pcv valve I am assuming you mean blow by. I have noticed no blow by what so ever. the idle reading is around 15-18 inches. Sound right?
Old 10-07-2010, 06:44 PM
bobbyjo9's Avatar
bobbyjo9
bobbyjo9 is offline
Yes... i was getting at blow by. Steady needle is good but that reading is low. Stock you should be looking at 20-21. How build is the motor? With a reading that low I would be looking for something close to the 700 hp range? Something is definitely off.
Old 10-07-2010, 07:39 PM
monsterbaby
Bobby look were he lives. He is at high altitude. 18 is about as high as you can get at 5000ft.
Have the engine builder check with a dial indicator the ACTUAL valve lift at the exhaust valves (all of them) He could be right in a bad cam and have some of the exhaust valves not opening far enough which would cause similar symptoms as a plugged exhaust.
Old 10-08-2010, 05:18 AM
85lebaront2
I don't know about setting up for high altitude, but 40 degrees at 2500 sounds a bit high for me. Have you tried backing the timing off a little to see if it makes a difference? I know back in the 70s we used to set up small block Chevy engines to run 38-42 degrees at around 3000, small block Fords we used 36-40 degrees at 3000.
I second the thought of checking all the exhaust valves for lift, heck, at that point, I would check all the valves and valve timing on each cylinder.
Old 10-08-2010, 10:03 AM
bobbyjo9's Avatar
bobbyjo9
bobbyjo9 is offline
wooops... my bad. I missed the altitude part. Living at 8ft sea level gets us kinna spoiled. Gotta be something in the valve timing... lift, binding, weak springs??? I may have missed this too but is this a roller motor or flat? A bad break in will smoke a flat cam.
Old 10-08-2010, 10:07 AM
85lebaront2
Yeah, Comp cams are real bad at smoking the lobes, I think they get their blanks from Chevrolet.
Old 10-08-2010, 10:27 AM
bobbyjo9's Avatar
bobbyjo9
bobbyjo9 is offline
haha
Old 10-08-2010, 11:03 AM
Big-old-460's Avatar
Big-old-460
Big-old-460 is offline
alot of times things like to cral in to your engine and Die. so far over night i have found rats in my air filer box, and a dead squril thing in my 6 inch pipe exhaust. you never know lol
Quick Reply: 460 weak performance
