1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
instrument panel electrical Oh Oh
Old 12-03-2010, 02:01 PM
hen04for's Avatar
hen04for
hen04for is offline
04 250 SuperD 140K miles, fantastic truck. This AM started fine but no Instrument panel. Everything, gas guage, oil pressure, speedometer, tach, odometer, trans temp and oil temp bottomed at ZERO. Changed 10 AMP fuse 35 and 41...old fuses looked OK, but changed em anyway. Turn signal indicator works, radio, wipers, everything else seems to be fine. Anyone have any clues?. Thanks
Old 12-03-2010, 02:21 PM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
what about fuse 45?
Old 12-03-2010, 02:22 PM
bpounds's Avatar
bpounds
bpounds is offline
Fuses sometimes fail but still look good. It would have been best if you had singled out the likely fuse, and then checked it with a VOM.
Old 12-03-2010, 02:36 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
The instrument cluster appears in my diagrams to be connected to fuses #33, 41 and 45. The Owner's Guide also mentions fuse 4, 35 and 41.
Old 12-03-2010, 03:11 PM
budman325's Avatar
budman325
budman325 is offline
It happened to me also last year, I work for Ford and 1 of the repairmen told me to unhook battery for awile and it will reset. I unhooked mine overnight and the next day everything was fine. never had a problem since.
Old 12-04-2010, 10:59 AM
hen04for's Avatar
hen04for
hen04for is offline
Thanks Fuse #45
Thanks to carltonwebb, bpounds, dchamberlain, budman325 for your responses. Fuse # 45 did the trick. Hoist a beer to you all. hen04for
Old 12-04-2010, 01:38 PM
03F2504x4's Avatar
03F2504x4
03F2504x4 is offline
This is obviously a newb question, but I've heard that sometimes the OD Off wire in the steering column can chafe and short which will cause the fuse to blow and the cluster to go dead. Is that true?
Old 12-04-2010, 02:04 PM
carltonwebb
Thats it. Fuse 45 is usually blown when that wire chafes.
Woodnthings sums it up here step by step
https://sites.google.com/site/woodnt...edirects=0&d=1
Up until sometime in late 03, it will take the throttle pedal circuit out when it goes. When they started wiring 04, they removed the throttle off of that fuse and left instrument cluster, tow/haul/ OD button and 4x4
Old 12-04-2010, 07:12 PM
Roasted7's Avatar
Roasted7
Roasted7 is offline
Yes this is true. Just happened to me about a week ago. I pushed the tow/haul button and my gage cluster went dead. Fuse #45.
wagonerkl
Large Truck
05-29-2017 11:18 PM
Matt1966
19
05-20-2017 08:55 AM
Harley Hill
25
10-07-2016 03:28 AM
cardsfanbj
1983 - 2012 Ranger & B-Series
02-25-2016 11:08 PM
grovermyson
1978 - 1996 Big Bronco
04-13-2008 04:24 PM
Quick Reply: instrument panel electrical Oh Oh
