Batteries are charged and good but truck won't turn over
About a week ago Mytryck started starting a little slower than usual but I thought with the Coker weather itwad not a big deal. Well it kept getting harder and harder to start as if the starter was struggling. So I checked the bolts and they were tight on the starter. I put the chargers on the batteries amd left them over night. Came out the next morning and my truck was dead. The batteries are charged but it won't even turn over. I just get this awful clicking Noise from the dash when I turn the key on. When I turn the key on the lights go Dim inside
I think should take your battteries to the store and have them load tested. They have probably ended their service life. Starter could be the problem as well but would lean more towards batts.
Batteries can display enough voltage when you check with a multimeter, but not be capable of handling a load such as cranking. Like the othes have said, take the batteries out and have them load tested.
You dont need to pull out the batteries to load test them. If you have a Meter, just have someone start your truck while you watch the voltage on the batteries for a significant drop while cranking your "load testing".
I thought about that. Had the starter been bad though, it could have given a false reading of low voltage b/c the starter was pulling too much juice. Thats the only reason I did not suggest it b/c starter was suspect. I did not figure he had a load tester to check them at home.
Thats true, I would always suspect batteries before the starter especially on our trucks.
