Stumbling 4.6L
P0300 is multiple cylinder misfires - that's why I'd verify the fuel pressure, as the fuel pressure effects all cylinders, just like the elbow on the back effects all cylinders.
On the other hand, Alloro is usually right . . . . .
fuel pressure is 43. Seems to run better after running it hard but it now comes and goes.
I was thinking I would replace the PCV valve, Can you tell me where that is? Also after I reset the codes, it has not had any come back, but has a few moments where it stumbles, then runs fine. Also when it stumbles there is no power, and if you floor it, and get to about 60, it starts running fine again?
Thanks for the help so far.
Are you sure you're looking in the right place?
Engine Performance problem 2003 Ford Expedition V8 Two Wheel Drive Automatic
