Power brake and steering hose HELP !
Hey guys.. its been a while since I've been on. Life has been very hectic for some time. I'm out in the bush working right now and the hose between the brake booster and the power steering pump has blown. This has happened twice now where it rubs through on the shock tower. Anyways... I McGyver'd it back together and its holding pressure but I've got a lot of air in the system... Can someone tell me how to blead this air out ?????????
Thanks Russ
Thanks Russ
Thanks guys... I actually jacked it up before I left this am and all was quiet in the pump.. it seemed like after I drove it last night a bit and parked it.. the air worked its way out by itself. I did work the wheel back and forth while it was jacked up for a bit just to make sure all was well and it seems to be good. You should see the fix we did here at the ranch !!! welded the old fittings onto and new section of hose and all.. Now the brand new altenator that I put on 5 days ago is acting up... don't think I can Mcgyver that one !
Mark... I'll call ya when I get out !
bikesandcars
12-15-2014 08:04 AM
Powerstroke1229
01-09-2013 10:35 PM
WilleyJoe.62
13
11-05-2012 11:20 AM
jomer
07-28-2005 08:31 PM
1999, 60, booster, brake, ford, hose, line, power, powerbrake, powersteering, powerstroke, sreering, steering, system
