how much louder without cats?
right now my truck has the two cats up front and then a one into two dual exhaust. its a generic muffler and its pretty quiet. i would say its about as loud as a stock truck but just a little deeper. how much louder will my truck be if i delete the two cats? will the truck smell while its running? -thanks
truck in sig
truck in sig
truck in sig
truck in sig
I'm running 2 1/4 straight pipes (no cats, no mufflers). I didn't see a huge difference when I took my cats off. When I chopped off the crapmasters and welded in a piece of pipe is when I noticed the most difference. It's LOUD now. Yes, it will smell, but again, you won't notice much of a noise difference with just taking off the cats. New York has emissions checks don't they?
I have a 95 5.8, I cut the front cat off, welded dual pipes on, and ran them to a 2 in/2out Magnaflow Stainless muffler with the x chamber, then duals out the back. I had to start it with the straight pipes on and boy was it loud! After I put the muffler on, it was too quiet. Its not much louder than stock @ idle, but gives you a nice crackle as the rpms come up. If I were to do it over, I'd go with two smaller magnaflows. The muffler I put on is REAL big and I had to shoe horn it in. Before I did that it had the front cat/collector, the rear and a cherry bomb, single pipe out the side. Had to have duals!
Are you sure New York is going to stop testing OBD I vehicles? I wonder if Texas is going to stop testing OBD I vehicles. I would think that if we still do it then sure NY does.
By the way, I wouldn't try to make that 300 too loud. It won't sound the way you want it to. A nice deep mellow sound is the best way to go for it.
