Sponsored by: Real Truck
Replacing Fog Lights.. HELP
Old Nov 30, 2010 | 02:07 PM
cricci121's Avatar
cricci121
Cool Replacing Fog Lights.. HELP
So i ordered a new oem set of fog lights because one of mine was broken so i got the lights in today and i go to take the old ones off and i unbolted the three screws holding them in then undid the plug and i had to break the lenses to get them to fit through the hole wear the front license plate is. I already took the grill off and the front license plate to get them out but how do i put the new ones in. They will not fit and i do not feel like taking the whole front bumper off? I have an 03 f250. help would be amazing.
Old Nov 30, 2010 | 02:52 PM
MPTonyT's Avatar
MPTonyT
Front bumper has to come off.
4 18mm bolts in the front and one or two 12 or 13mm bolts on either side and it come right off.
I always lay a comforter down to keep from scratching. I had to do this when i added HID's to the fogs.
Have fun and be patient.
Old Nov 30, 2010 | 02:57 PM
cricci121's Avatar
cricci121
I got them in and didn't take the bumper off. Thank lordy it still took me two hours tho.. thanks tho
Old Jun 17, 2011 | 06:38 PM
imockman's Avatar
imockman
Ok, so how did you do it with out taking the bumper off. I am having a similiar issue. Did you cut something?
Old Jun 22, 2011 | 09:17 AM
Wisebuck's Avatar
Wisebuck
Ditto, i have to change mine too so please share.
Old Jun 23, 2011 | 06:28 PM
imockman's Avatar
imockman
??? How ????
Well, One could disasemble the fog light units, put each piece through the lower slit in the grill... reassemble in the grille. I think I'll pull the front bumper.
Old Jun 26, 2011 | 01:49 PM
imockman's Avatar
imockman
lost the detailed reply I just made, so now for a quick one
4 18 MM bolt beside tow hook
2 Side support bolt (1/2 inch)
6 10mm bolts to hold fog lights to bumper
Tape Dish cloth to bumper ends, from end to side marker light at least
Use friend to help support bumper
Undo 1/2 bolt on each side, remove 18mm lower bolt by each tow hook.
Have friend support one side of bumper, remove upper 18mm bolt... Use knee to support bumper. Slide Bumper down to end of tow hook, rotate a gap between bumper top . This is big enough to remove and fit in fog light units. If you want to completeley remove bumper, remove splash guard clips attached to bottom of bumper before removing forwrd bolts. Install new units with M6 1.0 X20mm hex flanged cap screw. This will fit factory clip on back of 2002 F250 bumper (and probably 2003). Reverse above process to reinstall, use a disposable DVD case to set gap between bumper and head light. Just did this today, having right tools and fasteners as well as friend mandatory. Air Impact wrench makes final adjustments of gaps a lot easier, but could be done with socket wrench and some elbow grease.
Old Jul 7, 2011 | 11:39 AM
imockman's Avatar
imockman
Just changed my Avatar to share the fog lights
Ryan0214
15
Feb 14, 2013 07:50 PM
rlh68050
2009 - 2014 F150
Aug 14, 2010 03:00 PM
Gidg
May 1, 2009 12:02 PM
nut1605
Oct 31, 2007 05:13 PM
GreatNorthWoods
35
Aug 8, 2006 02:31 PM
