try pulling the steering wheel one way or the other. Sounds like the wheel has the pin in the column pressure on it. Just giggle the wheel while turning the key. i do it all the time when I park with the wheel turned toward the curb .
See if the wheel is up tight against the lock. Turn the wheel a little off of the stop and you should be able to turn the ignigition, or are you sure it's the right key or maybe it's someonelses ex in your driveway.
