Well it's not the edge evolution!
Old 05-24-2012, 09:04 PM
plomero2's Avatar
plomero2
plomero2 is offline
So back to square one. 6.0 70,000 2004. The water in the fuel light and the glow plug light is coming on and the truck goes to limp mode. Tried all fixes that anyone as said to try. We were thinking that it might be the edge evolution, so we unplugged it, for almost 2 week all was well, but today the truck did it again. So it's not the edge. I have replaced the fccm fuel sensor. Fuel filters. I would love some help. It is not the wire harness. Or the ficm. No codes come up. I am using a ford dealers scan tool.
Old 05-24-2012, 10:27 PM
KRDiesel's Avatar
KRDiesel
KRDiesel is offline
If i had to put money on it I would keep looking for a chafing wire. Or you could look for a chafing dish
Old 05-25-2012, 09:01 PM
plomero2's Avatar
plomero2
plomero2 is offline
Well it died again today. Ford said to try all grounds and make sure they are tight. It only does this at first start up. Out side temp and truck motor temp does not seem to matter. I need help please.
Old 05-25-2012, 09:29 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
What exactly is going on with it??
Truck just all the sudden turns on WIF Light and the Glow plug light on dash?? Runs Bad then dies or ?????????????
Is it just random or all the time???
Any recent work???
Old 05-25-2012, 09:41 PM
plomero2's Avatar
plomero2
plomero2 is offline
Any recent work???
The truck will start fine, but within a mile or two or just out of my drive way, it will go into a " limp mode". The water in the fuel light and the glow plug light comes on for like 3 seconds and then every thing goes beck to normal. I pull over and then it is fine. It has done it again a few seconds later, but only once or twice. It has done this for about 2 months now. It does not turn off but just goes to the limp mode. It will go some times a week or two with no problems. But then it will do it every morning or after I have been at work all day and start for home. I have drained the water in the fuel drain many times. Tried every other thing anyone has said might be the issue. So I hope that helps. Thanks.
Old 05-25-2012, 09:59 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Inttermittened problems SUCK
And this might be a PIA to figure out
Have you tried to start the truck and let it Idel and start wiggling the wire Harness around all over and try to make it act up with the problem also unplug things check for corrosion or dirty causing a bad connection
Just sounds electrical relaited
Old 05-25-2012, 10:05 PM
plomero2's Avatar
plomero2
plomero2 is offline
Ya it does suck. Sounds like some things to try next. Thanks for your time.
Old 05-25-2012, 10:17 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Next time it does do it start checking all sensor values while its in limp mode and Take Note what they are or if you see any value way off
Especialy Volts
When it Does go into limp mode does it recover on its own or are you turning truck off and starting back up
Old 05-25-2012, 10:32 PM
plomero2's Avatar
plomero2
plomero2 is offline
Especialy Volts
It recovers on it's own. The volts stay good. But I am using my brake controller to check volts. It has a real time read out on it. Thanks again!
Greenlawnracing
1999 to 2016 Super Duty
04-25-2014 08:33 AM
krazyone44
09-18-2013 11:43 AM
plomero2
05-24-2012 09:25 PM
Brian429
2004 - 2008 F150
03-18-2007 08:23 PM
Quick Reply: Well it's not the edge evolution!
