03 6.0 with low power
Old 05-22-2012, 09:04 PM
bpollard6.0-owner's Avatar
bpollard6.0-owner
bpollard6.0-owner is offline
I just replaced my number 7 injector and my icp. After putting it all back together it ran worst than before so I pulled it all back apart and it was better but it still has no power. I have to keep my foot in the radiator to go anywhere and can barely reach 30 mph. I have checked all of my connections to the injectors and FICM they were all good. Two codes injectors 5 and 7 low circuit voltage. I have no idea where else to go on trying to fix it any ideas??
Old 05-24-2012, 06:27 PM
grizzly11's Avatar
grizzly11
grizzly11 is offline
here is a bump for ya brenner
Old 05-24-2012, 07:10 PM
cheezit's Avatar
cheezit
cheezit is offline
why were you checking the ficm connecotrs when #7 is on the passanger side. should not of had a reason to play with them in the first place. more or less just tring to make sure you replaced the correct injecotr to start with
Old 05-24-2012, 07:29 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
Great Iddea
<TABLE border=0 cellSpacing=0 cellPadding=0 width=821 align=center height=1601 usegridy showgridy gridy="10" usegridx showgridx gridx="10" cool><TBODY><TR height=10><TD height=10 width=820 colSpan=6></TD><TD height=10 width=1><SPACER type="block" width="1" height="10"></TD></TR><TR height=30><TD height=1590 rowSpan=3 width=10></TD><TD height=30 vAlign=top width=200 colSpan=2 align=left content xpos="10" csheight="30">Return to Table of Contents</TD><TD height=30 width=610 colSpan=3></TD><TD height=30 width=1><SPACER type="block" width="1" height="30"></TD></TR><TR height=1050><TD height=1050 vAlign=top width=760 colSpan=4 align=left xpos="10"></TD><TD height=1560 rowSpan=2 width=50></TD><TD height=1050 width=1><SPACER type="block" width="1" height="1050"></TD></TR><TR height=510><TD height=510 vAlign=top width=90 content xpos="10" csheight="40">Page 6</TD><TD height=510 width=610 colSpan=2></TD><TD height=510 vAlign=top width=60 content xpos="710" csheight="30">Page 8</TD><TD height=510 width=1><SPACER type="block" width="1" height="510"></TD></TR><TR height=1 cntrlrow><TD height=1 width=10><SPACER type="block" width="10" height="1"></TD><TD height=1 width=90><SPACER type="block" width="90" height="1"></TD><TD height=1 width=110><SPACER type="block" width="110" height="1"></TD><TD height=1 width=500><SPACER type="block" width="500" height="1"></TD><TD height=1 width=60><SPACER type="block" width="60" height="1"></TD><TD height=1 width=50><SPACER type="block" width="50" height="1"></TD><TD height=1 width=1></TD></TR></TBODY></TABLE>
Old 05-24-2012, 07:30 PM
BLADE35's Avatar
BLADE35
Hows the FICM Voltage GOOD ???????????????????????????????????
Old 05-26-2012, 11:32 AM
bpollard6.0-owner
I know #7 is on the passenger side I checked the connection on the FICM to make sure nothing was loose.....How do I check my FICM voltage??
04HarleyDavidson250
1999 to 2016 Super Duty
06-08-2019 03:59 PM
04HarleyDavidson250
06-08-2019 03:58 PM
1973dieselhighboy
06-17-2011 09:05 PM
66gpw
05-08-2010 07:44 AM
Reelman1a1
20
07-28-2006 05:46 PM
Quick Reply: 03 6.0 with low power
