'51-'52 wiper assembly
  #31
Old 11-30-2010, 02:07 PM
hivolt5.0's Avatar
hivolt5.0
hivolt5.0 is offline
hivolt5.0 is starting off with a positive reputation.
I'm not sure how well it works, it's been sitting for awhile.
You know, I read on the HAMB several weeks ago about a guy who rebuilds vacuum wipers. Those that had used his services said he was very good and had a large supply of wiper motors. I'll have to search the HAMB and see if I can find the info.
  #32
Old 11-30-2010, 04:15 PM
hivolt5.0's Avatar
hivolt5.0
Here's the web link for the guy who restores vacuum wiper motors.
WiperMan.COM - Wipers, Wipers, Wipers
As I said before, several members of the HAMB recommend him.
  #33
Old 11-30-2010, 06:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Yes, I've heard good things about him, but there is nothing to these things! They have a leather seal and as long as the shaft is not wobbly, they usually just need cleaning and a seal. Dennis C and others used to carry the rebuild kits, haven't looked lately.
  #34
Old 11-30-2010, 09:18 PM
rhopper's Avatar
rhopper
rhopper is offline
rhopper has a good reputation on FTE.rhopper has a good reputation on FTE.
For my 48 F1, which had a single vacuum wiper, we swapped a dual vacuum assy from a 51/52. We did have to cut the under dash braces, and I'm not going to run a radio in the stock spot, so clearance wasn't an issue. We eventually converted it to electric, using a Jeep cherokee electric motor from the same jeep we pulled the steering column from, so the wiring is easy. It looks like a standard GM motor. It is attached to the stock linkage with a short, about 1", home made crank assy. I had to play with the linkage to get the sweep and park correct, but it works fine. With the jeep (GM) column and stalk mounted wiper switch, it has intermitent speed like any other Gm car.
  #35
Old 11-30-2010, 10:33 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by rhopper View Post
For my 48 F1, which had a single vacuum wiper, we swapped a dual vacuum assy from a 51/52. ....
I'd appreciate picture, if you've got one. I'm figuring to do something similar. BTW the wiring for a GM is no treat if you don't have the column!!
  #36
Old 11-30-2010, 11:46 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.
OK, here are a couple of pics under the dash of my 49. These are taken from the passenger side through the glove box opening. You can see how the braces in my truck have been modified by a PO for radio fitment...LOL
Sorry it took me so long to get these up, my modem bit the dirt today and I've been trying to get re-"connected"
  #37
Old 12-01-2010, 12:42 AM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Here are the pictures I took today from underneath the instrument panel of my 51. I didn't see any braces like in Bobby's pictures.
  #38
Old 12-01-2010, 09:38 PM
rhopper's Avatar
rhopper
rhopper is offline
Ross, I'll take some pictures and post them. BTW, my wife and I will be passing through Albuquerque the end of this month, staying overnight on the way to Phoenix. You and Bobby going to be around?
As far as the wiring, I originally went with a junkyard s10 motor, couldn't make sense of the wiring, and went back for the cherokee. The wire colors match the harness from the bottom of the column, and I was able to test the whole thing on the floor before installing. I going to have to make a harness from the column to the motor, but I have the connectors for both ends, and again, the colors match.
Rusty
  #39
Old 12-02-2010, 07:48 AM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Rusty,
As far as I know I'll be around. If you got time when you're in Alb let me know.
Ross and I live pretty close to one another.
I'm intrested in see a pic of the Cherokee motor set up as well. I'm at the stage of trying to decide what motor to use on my 49.
Bobby
  #40
Old 12-02-2010, 09:17 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I should be around, too! Send an email, we can set it up! There are 3 or 4 others in the area, maybe we can have a get-together.
  #41
Old 12-02-2010, 09:44 AM
ibuzzard's Avatar
ibuzzard
ibuzzard is online now
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
May Dan and I jet in and attend this soiree?
  #42
Old 12-02-2010, 09:59 AM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
I'll just be the fly on the wall.
  #43
Old 12-02-2010, 11:46 AM
ibuzzard's Avatar
ibuzzard
Smart man.Save your money and sanity.
  #44
Old 12-02-2010, 03:59 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is online now
bobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant future
I'll be there in mind and spirit, oh wait, with what is going on in my life right now I'm losing my mind so I might only be able to be there in spirit but that's taking a beating right now too. Well, I'll just think about it then.
  #45
Old 12-02-2010, 05:55 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Spirits? did someone say spirits???
...well, maybe a wee drop to quench me parched throat....
Quick Reply: '51-'52 wiper assembly
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
