Anyone running axle trusses?
I am looking into building some axle trusses for my 79 Bronco. I am not ready to part with the money to put 1 tons under it yet so I have to make due with the half ton stuff. I am worried about bending/ breaking the axle housings if for some reason the truck gets airborne. I am pretty savvy with metal fabbing and so forth, I have torches, welders, etc... and access to a tubing bender. I pretty much have a game plan for the rear but not totally sure how to go about bracing up the front. I was hoping some of you guys might have a few ideas or better yet some pictures of how to brace up the D44 front axle. Any and all feedback is appreciated!
John
John
John
John
Good idea John...
******** width="640" height="385"><param name="movie" value="http://www.youtube.com/v/u1IVvz6Sd0Q?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/u1IVvz6Sd0Q?fs=1&hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed>*********>
Good idea John...
John
Oregonmudder... yep thats pretty much what I was thinking for the the rear axle, I was also looking into running a brace across the back of the housing too. Hmm that blown out 3rd member looks awful familar too, you must have one of the those "experimental" front wheel drive trucks! I just broke mine the same way hopefully the nodular center section I plan to order will fix that.
Bender99... I like the tube style brace you made, I may go that route also. What diameter and wall thickness did you use? From the looks of it I would be best off to brace the top and bottom side of the D44. I was kind of hoping I could get away with just doing the top, mainly for ground clearance reasons. Thanx again guys.
John
John
Yeah, I haven't heard much of anything good about the factory center sections. I am looking into an aftermarket nodular iron unit, I don't want that to happen again. It trashed the center section, R&P, the drive shaft, busted the yoke on the t-case, f^(#ed up the brand new exhaust, and beat the crap out of the bottom of the truck. It aint gonna be cheap to fix either.
Received 3,102 Likes
on
several years ago Tom. That is the carrier that I had in the Ranger and is now in the Galaxie.
When I first built the ranger with a small block I put a factory N case in, but when I built the big block I didn't want to chance it so bought that.
