Modular V10 (6.8l)
Pinging
Old 04-17-2016, 06:30 PM
perryg114's Avatar
perryg114
perryg114 is offline
Pinging
I am getting pinging under moderate load but not when I let off and not at full throttle. I think it is the knock sensors. I watched the spark timing on my scanguage and the spark timing when it pings is in the mid 20's. When I hit the throttle it drops to about 10 degrees. It does not seem to be sensing the knock or at least not consistently. I wonder if there is a way to monitor the knock sensors with the scanguage? I don't think this is good for the engine. The knock can be stopped by changing the timing so I don't think there is anything wrong with the engine. If it were a vacuum leak or some other problem I don't think it would go away.
Perry
Old 04-18-2016, 08:20 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
You CAN monitor the knock sensor, but I forget what the PIDs are called.
The knock sensor algorithm can only take 4 degrees of timing out. Sounds like something else is going on, such as a vacuum leak.
Old 04-19-2016, 02:00 PM
perryg114's Avatar
perryg114
Well I don't think it is taking that 4 degrees out. So where do I start?
Perry
muscletruck7379
04-25-2011 08:39 PM
Hellbore
05-31-2006 08:45 PM
phoneman91
03-25-2006 05:07 PM
mosfet
1997 - 2003 F150
11-11-2005 03:03 PM
propellerhead
Computer Chips & Tuners
11-24-2004 09:38 AM
Quick Reply: Pinging
