"88" f-150, Fuel Supply- intermittent, starts, runs short time fuel stops pumping.
My f-150 w/dual tanks (donot use rear tank) has been a great gal. Always gets me home....Now I overheated her on a short run. Got home ,left her running and got some coolant in her; then parked her till next day. She would not start- out of gas....refueled her; started up and when I dropped her in gear, She quit..Would turn over,but no start. etc.. Checked spark, fuel. Again she starts, run a short time and just dies..My chilton has been a fair/good referance. But have not been able to fix issue. If she JUST would not start I would replace "whatever".. But the start/stop-start/stop has me confused. Help!
You say you overheated it? When it wont start, check for power to the fuel pumps. Start by pulling the relay or fuse then test, then try to get at your connections and make sure you have power and ground going to your fuel pump. You could have weakened a wire or contact point. Seem someone do this recently and threw almost a 1000 bucks at a 5.00 fix.
As subford said, there is a list of things it could be. Your TFI, Fuel pump it self. MAke sure you have power and ground to the pump and see what goes
ng19delta
17
03-30-2015 10:27 PM
RANGER589
18
06-03-2011 10:03 AM
K8's Ford
13
10-19-2010 05:39 PM
fmr9
40
11-01-2007 11:35 AM
Oil-Pig
18
02-08-2007 06:18 PM
