6.0 powerstroke " how's it sound to you?"
Old 03-20-2016, 01:30 PM
Atom1234's Avatar
Atom1234
Atom1234 is offline
This is a video of my 6.0 powerstroke after sitting for weeks and it was 45degrees f . It's my first and it sounds noisey , but what do I know tell me what you think .
Old 03-20-2016, 01:37 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
you running 5w-40 full synthetic oil? if not, you should. Sounds a little rough at first, could be a little stiction, they all sound lumpy when cold.
Old 03-20-2016, 02:29 PM
Atom1234's Avatar
Atom1234
Atom1234 is offline
What is stiction?do you hear any negative noise it does quiet down a little when it warms up.
Old 03-20-2016, 05:18 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
I don't hear anything terribly out of the ordinary on it.
Old 03-20-2016, 08:38 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
It sounds ok to me also, maybe a little bit stumbling when it first fired up but it straightened up pretty quick. The stumble would be a common symptom of stiction. Basically, oil deposits on the small parts inside the fuel injectors cause them to stick just a little bit on cold starts. It usuially gets worse over time or when engine temp is colder. If you would prefer it to be a little quieter, you could try some Archoil Addative next oil change. Many people here like it. I've tried it myself and I didn't see much improvement in cold idle quality but it did make the engine noticeably quieter.
Much of the sound you are hearing is the diesel ignition noise, it does sound "mechanical" but it's common to diesels and maybe a little more noticeable on this particular engine.
BOLINJORDAN
05-27-2008 11:26 PM
JoeAndre
01-22-2008 06:25 PM
spycatcher70
02-27-2006 04:46 AM
momofcrts
Aerostar
08-08-2003 08:41 PM
Quick Reply: 6.0 powerstroke " how's it sound to you?"
