reverse sensor issue.
Old Nov 26, 2010 | 02:49 PM
ford2000ex's Avatar
ford2000ex
I noticed something weird.... my reverse senors only work correctly about - 40 degrees F. idk why every other time i place the car in reverse it just beeps untill i turn it off... anyone know what might be the issue?
Old Nov 26, 2010 | 03:12 PM
EMC V10 X's Avatar
EMC V10 X
Check to see if there is ice or condensation on them. It happens to my wifes van more than my excursion...
Old Nov 26, 2010 | 08:22 PM
ford2000ex's Avatar
ford2000ex
no its always in the garage so it never sees ice build up.. umm but every time its below 40. they work like if they didnt have a issue.. once it gets warmer about 50 + they stop working...
Old Nov 28, 2010 | 07:33 PM
ford_model'a''s Avatar
ford_model'a'
My 2000 EX has had a similar problem which I eventually solved with the old "remove and replace method" costly but it works. I bought a new sensor and started to swap it out with each one. That will work if only one sensor is bad, but I had two bad ones and bought another new sensor and replaced them in pairs and now everything is working correctly.
You can check out this old thread to read what others have tried with theirs.
https://www.ford-trucks.com/forums/2...cal-issue.html
Hope this helps
troupstree
Jul 7, 2014 11:17 AM
Kamstutz
Nov 19, 2012 04:37 PM
cray0971
Aug 25, 2011 08:46 AM
GreenMachine'77
Nov 22, 2006 11:40 PM
samensi
Sep 26, 2006 07:48 AM
