4.9 EFI engine Idling Very Fast
Old Nov 26, 2010 | 07:20 AM
axle234's Avatar
axle234
Changed out the lower manifold on a 4.9, Now the engine is idling very fast - over 4000 rpm. Gaskets appear to be in place and vacumn lines. Any suggestions? If I cover the ports on the throttle body the engine keeps running.
Old Nov 26, 2010 | 07:41 AM
TexasGuy001's Avatar
TexasGuy001
The engine should still run with the throttle body blocked off, because the IAC is allowing a small amount of air in so it will idle. The IAC could be your problem with the high idle. I would think a vacuum leak will make it surge.
Old Nov 26, 2010 | 07:58 AM
axle234's Avatar
axle234
Is the IAC located on the trottle body? Is there a way to test it?
Jhow88
Nov 12, 2014 08:36 AM
blue924.9
13
Dec 8, 2013 04:09 PM
rlwilson2
13
Dec 13, 2012 04:05 PM
danshot
Mar 15, 2012 05:39 AM
1990 4x4 Tuff
British Columbia
Nov 30, 2008 09:33 AM
