Bet my truck is cleaner than your truck!
(At least my interior!)
My truck prior to me owning it was a no AC truck. It lived in the desert and I can only assume the windows were wide open all the time. (I put in factory AC since owning it)
I started off wanting to do something about the faint dusty smell.
I pulled out everything but the main body of the dash. (cluster had already been cleaned and replaced as had the glovebox.
Turns out everything was full of dust:
A good washing out and vacuuming the residual water and it started looking like this (I'm planning on priming the scuffed areas where there was some wear, then shooting the floor, back wall, and B pillars with lizardskin):
I also used a sound damping material on the roof to cut down on noise:
I also washed all the interior components:
I will add pictures tomorrow, but I fully disassembled the seat, washed the frame, and fabric.
This thing probably hasn't been this clean since the day it was first bought!
Too many days that has happened.
thordehr.... You should dynamat the back and bottom of the cab. Makes a difference!. Nice job...... By the way...I bet you find more to clean if ya remove the bed too! hehe
