Heater core F250
Heater core F250
My 03 F250 7.3 Diesel apparently has a problem with the heater core. No fluid inside the cab but does have the anti-freeze fog on the lower right corner of the windshield just above the defroster outlet over the heater core. Have been told that there are "quick couplers" that hook the core to the water system. Is this so and if there is, do you still have all of the labor expense of removing the whole dash? Understand that the labor bill from a Ford dealer for removing the dash is near $1,000. Can this be right? Thanks
do it yourself, about 1hr labor, just did it on my 2000 F250, no need to take the dash out, just glove box. Quick connects on the engine side, take several screws out of the core cover and 4 (?) of the other plastic part not sure what it called, but you will see it when you get to it, on the upper left side of the heater core.
Good luck!
Good luck!
sholloway
01-04-2013 06:26 AM
Cajunrail
02-25-2004 12:19 PM
