Sponsored by: Real Truck
Code P2033
Old Nov 23, 2010 | 01:47 PM
tlawssss's Avatar
tlawssss
Code P2033
Getting a code of P2033- Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor
I was driving home the other day and the regen kicked in and this code popped up. I wasnt able to finish the regen. Later that day I headed out again in the truck and the code was gone. It went into regen almost immediately after driving and it completed the cycle after about 40 minutes of driving. No code now. It seems as lately its going into regen every 50 miles. Can somebody shed some light on the subject and let me know what they think is going on. Thanks in advance. How much is this gonna cost me at the stealership?
I read somewhere about a bad EGT sensor.
08 f250 6.4 liter with about 62,000 miles.
Old Nov 23, 2010 | 05:31 PM
bpounds's Avatar
bpounds
Should not cost you more than $100, and since it is emissions related should cost you $0. As long as it is stock and not caused by something you've done or neglected.
Old Apr 27, 2011 | 03:59 PM
ford64350's Avatar
ford64350
what if you already replaced the sensor cleared the code and it came back?
Old Apr 27, 2011 | 04:13 PM
bpounds's Avatar
bpounds
You have a 5 year/100k mile warranty on an emission problem. Are you past that?
Old Apr 27, 2011 | 04:26 PM
senix's Avatar
senix
If you cleared the code then the sensor is suspect.
Old Apr 27, 2011 | 04:32 PM
bpounds's Avatar
bpounds
Or else you changed the wrong one.
Old Apr 27, 2011 | 04:51 PM
senix's Avatar
senix
P2033 X
Sensor Circuit High
Bank 1 Sensor 2
This error occurs when the EGT2 sensor temperature signal
is lower (higher voltage signal) than a minimum probable
temperature, indicating an open circuit or a short to power.
Old Apr 27, 2011 | 05:30 PM
ford64350's Avatar
ford64350
Sensor two would be the one on top of the converter right.
Old Apr 27, 2011 | 05:31 PM
ford64350's Avatar
ford64350
Yeah out of warranty I have 138,000
Old Apr 27, 2011 | 05:46 PM
senix's Avatar
senix
i beleive so.
Old Apr 27, 2011 | 08:57 PM
tlawssss's Avatar
tlawssss
It ended up costing me around 300 or so dollars to have Ford change my sensor when it went out. I was with in the five year and 100,000 mile warranty, but they told me it was not something that would qualify. Now I am wondering if I was ripped off.
Old Apr 28, 2011 | 05:09 AM
senix's Avatar
senix
there was a change to the warranty where they are not covering these now.
Old Jun 23, 2012 | 07:34 PM
fendelander's Avatar
fendelander
P-2033 code EGT 2 sensor
Does anyone know the part number for this sensor?
tracyclifton
6.7L Power Stroke Diesel
22
Aug 21, 2021 08:31 PM
Aaron Green
General Diesel Discussion
21
Mar 8, 2016 11:20 PM
Jefff H
Sep 10, 2015 02:29 PM
rmrichards949
66
Jul 25, 2013 02:40 PM
testczar
Feb 16, 2012 07:28 AM
