1956 LONGBED WOOD IDEAS?
I used common spruce- really cheap, easy to get more if/when I need it. I plained it down to thickness, cut in edge chanels for the metal retaining strips, and marine spar varnished the heck out of it before assembly. A couple of years old, always kept under cover, still looks great. Truck is F-68 with express box.
As long as you protect the wood with a good finish you can use whatever you like IMHO.
I used birch plywood, with some special rating on the glue ("exterior" or some such thing). It was about $30 a sheet back then. I was not so concerned with durability or water, we never get rain here, and scratches or such don't bother me. The birch side is finely finished and takes stain great.
Are express box boards more than 96" long? Are they the same thickness as short box? I always wanted to make a box with loblolly pine scaffold-grade boards, that stuff is indestructable.
Bruce Horkey sells longbed wood kits in a variety of woods. His prices are right in line with everyone elses.
Ford Bed Wood
And these guys, too...
http://bedwoodandparts.com/i-2895152...de-pickup.html
Ford Bed Wood
You might also give the guys at Northern Classics a call. They don't list long bed wood in the website, but they might be able to make it anyway:
Northern Classic Trucks - Reproduction parts for your antique Ford truck .
i just helped my friend do his 65 bed, he bought Trex decking material.
he will never have to do it again.
Decking Colors | Trex
Understand cheap (frugal) I think the were originally yellow pine. When I did my 54 I used white oak and milled the groves for the strips (maybe the local High or vocational school might be able to help) Bed strips might be obtained from a truck dealer (flat bed). There should be some lumber mills in Ohio where you should get your choice of wood. Galvanized carriage bolts, nuts and washers.
One board foot is 12 in. x 12 in. x 1 in., in other words, a 6 in. board 2 ft. long is 1 board foot. I agree about the cost of these wood beds being extravagant. You can go down to the lumber yard and get shop grade lumber in a variety of species a lot cheaper. If you have access to a table saw or router they are really easy to reproduce.
