Clutch slave cylinder problem or is it master cylinder
Clutch pedal goes to floor, with no resistance. Master cyl for brakes has fluid, is the slave cyl bad? If so, any tricks to replacing, and removing air from line?
Now that she's a running I can't wait to take it on the road!
Thank you, C
Happy Thanksgiving!
Thank you, C
Happy Thanksgiving!
The pre-bled master slave is the easiest to install but expensive, and it didn't last too long. Last time I changed my slave I just swapped out the old for new, pumped it with my finger while laying under the truck about 100 times and it still didn't work. I had to remove the master from the firewall and point it down, pump it several times to work the air I had pumped into that line out, then go back down to the slave and pump it a whole bunch more.
I'd suggest pulling the master from the firewall and let it dangle so any air bubbles coming up from the slave don't get sidetracked into the master line. Then just remove the old and stick on the new and pump the little rod with your finger. If you have a helper, have them watch for bubbles in the reservoir, then give it another 20 pumps for good measure and you should be good to go in half the time I spent messing with it.
i had zero issues when i did my slave cylinder, i did it in about 20 mins taking my time, just pop the line of, replace the oring, put the codder pin back in and i bled mine by hand because the new one didn't have a bleeder on it, just hand pump the rod back and forth you will tell when all the air is out, just be careful to not empty the res. or you will pump more air in.
slaves go out all the time, there rather cheap to be honest, the front seal if you take apart the slave, they hold all the pressure, so they go and leak past it and bleed it all out. just get anoher slave, VERY easy to replace and cheap, unlike 99 rangers... pull the tranny to do em! uhg!
I've gone through 13 slave cylinders on my truck. I'm confident I can have one changed in about 10-15 minutes, bled and running down the road. I have never unbolted the clutch master to bleed them. I just pump the slave by hand a few times, get out and fill the rez some more, then back to pumping again..
Edit, I only went through that many because the pivot arm for the throwout bearing was broken and was twisting on the throwout bearing making the slaves go out all the time. I got that fixed and haven't been through anymore yet.
I'm on it! thanks for the great replies. That, and a brake line, and i can take her for a spin !!!!! the fact tha the truck has come together, and it's the last week of deer season, has made for some very full days! No luck yet, a 10 pt buck ran past my stand opening morning , and i haven't seen any good ones since
I had to change slave cylinders pretty quick several times when one would go out on my way to work or something. Driving without a clutch in town sucks so I would swing into an auto parts store parking lot and change it out real quick and run about my business. haha
After I fixed the clutch lever for the throwout bearing I put in a new slave cylinder from Advance and a new master cylinder. Ran that stuff for a year with no issues then something came apart earlier this year. Fluid came from something and I got tired of messing with it so I went to Ford and got a new slave and a new line. Put that in and the master started blowing fluid so I went to Advance and got a new master and put that on b/c it was Saturday and Ford was already closed.
Haven't had any issues, but my clutch pedal is NOT consistant and I think the clutch master is to blame for that. I will get a complete pre-bled unit next time around, but I don't think the hydraulics are to blame. I think the sleeve that the throwout bearing slides on also needs attention.. I got something to fix that issue too.. Can you say full cryo'd ZF??? LOL
The first 12 were all parts store parts. Advance, Oreillys, A-Line, etc. Tried them all including the ones with bleeder screws and the ones without bleeders on them.
My throwout is starting to make a bunch of noise so I guess I'll be pulling a tranny soon. If you figure out how to cryo a plastic POS throwout let me know.
