C4 Valve Body Question
I am rebuilding a C4 transmission and did my first bone headed move. I took care to keep each of the springs and valves that came from each hole separate so I would know where each set goes....but...I didn't pay enough attention to the 2-3 backout valve. It has two springs that are the same diameter and one is just slightly longer than the other. Does anyone by chance know whether the longer or shorter spring goes down the port/hole first? Thanks.
Received 5,155 Likes
on
Chump, dude, you are the man. Thanks. I had posted this elsewhere and gotten similar information (slightly different lengths) but it reinforces what I have seen on three occasions now which is.....large spring in first. You guys take a slightly stressful situation (hard to get this info) and make it all go away. Thank you.
shark13
11-23-2010 10:58 PM
tapenick
02-04-2003 09:28 AM
