My exhaust leak story/warning
So, after this latest experience, I think it is worth posting about. I had noticed some faint exhaust smell from time to time with the heater...or at least I thought I only noticed it from time to time. I usually chalked it up to exhaust coming in cause the window was cracked, or the door being open when I started the truck. After a trip to npccpartsman's house, we found that I had leaks at the manifold on the passenger side. I spent today installing a manifold gasket. As soon as I finished the job and showered up, I hit the road back home from the holiday. It's about a 2.5 hour drive, and I had the heater going to some degree the whole time. When I said I only THOUGHT there was exhaust in the cab from time to time, I was wrong. During the drive home, the difference in air quality in the cab was VERY noticeable. It's hard to describe, but I would have never noticed the difference until the job was done.
If you know you have a leak, or even think you have a leak, fix it. I'm by no means a master mechanic, and to be honest, the prospect of doing a manifold gasket on my own intimidated me. I'm competent enough with a wrench, but still. I was able to do the job on my own, totally unsupervised, taking my sweet time, in a little under 4 hours. That includes a break or two for frustration, and one for a quick bite to eat. The hardest part for me was working with these big sandwich clamps in somewhat tight spaces.
Even once we found I had the leak, I wasn't too worried about it. We only found it less than a week ago, so by no means was I procrastinating. But, if I hadn't had the extra time from the holidays, I probably would have put it off thinking that 90% of the time, it wasn't noticeable, so logic says it's not bad, right? Yeah, I was wrong. If you think you have a leak, or especially if you know it, just fix it.
You should have one like I had...Had to completely scrub the interior down after I fixed it. And try it in the dead of winter when diesels don't burn fuel very efficently...wow! My daughter went to town with me, -20 and we had the windows down, and she was streaming tears and sick! Should have got after it earlier, was too busy with fall work.
Why no gaskets from factory?
Should I go back and put gaskets on as a preventative measure, and if so what are the part numbers?
Exhaust manifold gasket 6C3Z-9448-A.
Fel Pro MS96833
The factory gaskets come one at a time and are two layer metal gaskets.
Thanks npccpartsman, Glad someone gets up as early as I do......
I wasn't thrilled about the idea of pulling the mani's...I just did the head gaskets and have all the wrench time I need for a while......
Sitting here catching up on the forum and watching the end of Boise St. and Nevada that I didn't see last night. Have no idea what the outcome is but it's in overtime......GO NEVADA.
What a game that must have been!!
Now if only Auburn and Oregon could have lost!!
(Go Oklahoma State)
Glad you are getting your truck where you want it EODguyJake.
I am a little jealous of all you have gotten done to it. Did you notice I went w/ the Duratracs also (at least I believe I was told that you had installed them also - hope I am remembering correctly).
(Go Oklahoma State)
Boise State had their chance at the end of regulation and their kicker blew it twice (once in OT also).
Auburn HAD to win so the Hogs can beat LSU and go to the Sugar Bowl.
Jake does have the Duratracs on his truck and seems to like them quite a bit. I know they are a LOT quieter than the Nitto's he had and they seem to ride and drive a lot better too. None of the wiggle/wander I've heard about.
I was going to ask a friend that's a heavy equip mechanic to help with my head gasket replacement, but his hands are HUGE and I knew that wouldn't work....
Sometimes it pays to be a skinny guy.
Honestly??? I don't have any way to read the temps. Maybe Santa will bring me something. The truck "seems" to like it a lot though. My unit has a thermostat that a lot of the earlier units didn't have. I guess I'll have to talk Jake out of his DD for a bit so I can datalog it and see, although the only comparable temps I have are in HOT (105*+) weather.
I don't know about other years but In 2005, the engines shipped from the factory without exhaust manifold gaskets. The heads and the manifolds are machined for a leak-free fit. It was probably done for cost savings in the manufacturing process. All automotive manufacturers, heavy trucks included, do what they can to save pennies at every step of the build process. It's the same reason that front hub assemblies can no longer be disassembled and serviced. In the past, it cost time and money to pack and set bearings in the hub as it was attached to the axle. Now, a factory in Mexico can stamp out hub assemblies at a fraction of the cost it takes to put one together on the vehicle assembly line.
