heater hose elbow - Ford Truck Enthusiasts Forums
heater hose elbow
Old 11-22-2010, 11:53 AM
hollygreenman
hollygreenman is offline
hollygreenman is starting off with a positive reputation.
heater hose elbow
I had to remove mine - it was leaking due to bad corrosion. Sooo, I can't find the part # B7A 18599-B anywhere. The local Ford guy said he didn't think it was anywhere across the nation. I probably could rig something up at the hardware store, but I'm wondering the function of the long pressed in pipe into the threaded part of the elbow. Restrictor? Maybe to prevent air cavitation? Baffle to prevent sloshing?
Bottom line is: must I have that pressed in pipe that puts it deeper into the manifold or just use common pipe elbow and not worry about it?
Old 11-22-2010, 12:48 PM
jowilker's Avatar
jowilker
jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
You should be able to eliminate it. I don't have one in mine. I do have a valve inline near the firewall to close off flow for warmer weather.
Should you want to keep it, a 1/2" copper plumbing pipe 90 will work perfectly. You can use a straight piece of the pipe to mend any area.
Just use regular hose clamps.
John
Old 11-22-2010, 11:51 PM
tbm3fan's Avatar
tbm3fan
tbm3fan is offline
tbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to behold
Didn't say which engine you have but one can find both sizes via a Mustang supplier like NPD. Page 170 in the Mustang catalog in upper right corner shows elbows. If the typical 3/4' opening in intake then you want #10 for an FE engine. The small blocks always take # 1A or 1B. All take a 5/8" heater hose.
National Part Depot
click link and at red tool bar at the top type in page 170 and hit enter to load the page to see for yourself.
Old 12-03-2010, 01:23 PM
hollygreenman
Thanks, John and Mike. I ended up ordering one from NPD. It was the wrong size as it was 3/8 NPT. Mine, off the 352, was 1/2 NPT. I just went to the local ACE and bought a steel reducer bushing. Don't foresee any problems with that as it only goes to the heater core.
Old 12-03-2010, 03:13 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Originally Posted by hollygreenman View Post
I had to remove mine - it was leaking due to bad corrosion. Sooo, I can't find the part # B7A 18599-B anywhere. The local Ford guy said he didn't think it was anywhere across the nation. I probably could rig something up at the hardware store.
Did your local Ford guy happen to look in his O-S-I Catalog...then pass the following info along?
Obviously not.
B7A18599B replaced B7A18599A due to a packaging change. The only difference between the two numbers is the suffix.
CARPENTER NOS OBSOLETE PARTS has TWO B7A18599A = 800-476-9653.
No Ford Dealer or other obsolete part vendor has any of either number.
Old 03-31-2018, 01:30 PM
prosper65
prosper65 is offline
prosper65 is starting off with a positive reputation.
3/4 in. heater elbow
Is that part # for a 1/2 in. or a 3/4 . I am looking for the 3/4 in. thread elbow.
Old 03-31-2018, 01:38 PM
NumberDummy
You are responding to a 7+ year old thread.
These trucks use 5/8" I.D. heater hose, and a 5/8" I.D. by pass hose if it's a 1965/66 352.
No 1961/79 F100/350 has 3/4" I.D. heater hoses. If the engine was swapped from a car = 1968/78 misc. Passenger Cars: One heater hose is 5/8" the other is 3/4."
But, the heater cores used on these trucks have two 5/8" I.D. nipples.
Old 03-31-2018, 02:54 PM
willowbilly3
willowbilly3 is offline
willowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to all
I did mine on my 59 292 with hardware store brass fittings and no pipe. I is the standard heater so had a shut off valve and I just used a ball check valve. It's been working fine all winter
Old 03-31-2018, 09:01 PM
prosper65
The engine is a 352 from a 1965 f100. The heater inlet elbow has 3/4in. threads and looks original to the engine. I would like to find the same elbow to replace it. I can't seem to find a part # though.
Old 03-31-2018, 11:34 PM
NumberDummy
The threads are 3/4" but the nipples are 5/8" I.D. There are two different types of these puppies.
May be available from auto parts stores, as both were used on 1949 and later myriad FoMoCo vehicles.
8A-18599 .. Elbow - Heater to Water Pump - 3/4" pipe thread / Obsolete
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
OBSOLETE RELIABLE PARTS in Nashville GA has 1 = 229-686-5101.
8M-18599 .. Elbow Straight - Heater Hose to Water Pump or Hot Water Return - 3/4" pipe thread / Obsolete
NOS PARTS SOURCE has 1.
MUSTANG'S ETC. in Van Nuys CA has 1 = 818-787-7634.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
MUSTANG SERVICE CENTER in North Hollywood CA has 1 = 818-765-9266.
Old 04-01-2018, 07:54 AM
prosper65
thank you for your help
abe
06-06-2016 09:14 PM
bubba.whit6.4
6.4L Power Stroke Diesel
06-01-2016 03:24 PM
bcaughhorn
16
07-11-2015 12:13 AM
Psyclopse
05-07-2015 02:02 PM
timmygyu
1968-2013 Full Size Vans
04-25-2014 04:29 AM
Quick Reply: heater hose elbow
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
