Duraspark II Conversion - How To
Old 02-21-2014, 07:14 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
You are in the wrong forum. Over at 80-86 we have all that info in our stickies.
DS-II Wiring
  #107
Old 02-24-2014, 04:51 PM
scott.t.wetter's Avatar
scott.t.wetter
scott.t.wetter is offline
Couple a questions
So- I've got your same deal- '84 F-150 with the 4.9L I6. I've got the parts on order and I'm getting ready to do the conversion. I went with an '80 stock carb, the duraspark dizzy, icm, coil, and I'll build my own harness with the connectors I ordered. The only real question I have is dealing with the smog holes on my engine. Any advice? I'm assuming since I'm not replacing the intake manifold that I'll have some stuff to cover up. Also, I'm curious about the valve cover gasket connections. I'm going to get a filtered oil fill cap but it sounds like I'll still have to run a PCV on the back hole to the carb???? Just want to make sure all my ducks are in line before I start turning wrenches. Thanks for the great write up, it's gospel I've been pouring over getting ready for my conversion.
  #108
Old 02-24-2014, 08:21 PM
Sean_Memphis's Avatar
Sean_Memphis
Sean_Memphis is offline
I haven't gotten that deap into my project. I'm keeping the stock intake and 1bbl Carter. I have a little soldering to do and then I will swap the dist. Hopefully by this weekend.
  #109
Old 02-24-2014, 11:39 PM
scott.t.wetter
Sorry
I thought I was replying on a duraspark conversion for my truck
  #110
Old 02-25-2014, 12:22 AM
Sean_Memphis
You are, but you don't have to swap out your intake and I'm not.
  #111
Old 02-25-2014, 04:33 AM
scott.t.wetter
Ok thanks
I was just concerned about smog holes. I'm still learning hence my reason for buying this project
  #112
Old 02-25-2014, 02:54 PM
Sean_Memphis
[QUOTE=scott.t.wetter;14105384]I was just concerned about smog holes. I'm still learning hence my reason for buying this project[/QUOT
E]
You can just plug the the holes on the existing intake.
  #113
Old 02-28-2014, 07:21 PM
Sean_Memphis
Well, I finally got my distributor and harness, etc installed (I will post a couple of pics later/It works and runs though LOL I'm not sure what I'm going to do w/the egr yet though. What did everyone do?
  #114
Old 02-28-2014, 07:24 PM
Sean_Memphis
  #115
Old 02-28-2014, 07:26 PM
Sean_Memphis
  #116
Old 06-12-2014, 09:18 AM
ghostshark's Avatar
ghostshark
ghostshark is offline
I just did this conversion computer delete too.
Used my TFI coil
bought a new DSII dizzy single vac advance at oreillys, It was not to bad at all.
I dont have a blow by blow on it all because I live under my hood so I'm always doing something.
But Heres my current pic, I went out an took this just now in the rain just for yall so dont judge the finger in the pic lol.
  #117
Old 06-12-2014, 11:05 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
Looks nice! Was your truck at one time a 3-on-the-tree?
  #118
Old 06-12-2014, 11:07 AM
ghostshark's Avatar
ghostshark
It was originally the old owner converted it to what it is now. 4 on the floor lol
  #119
Old 06-12-2014, 04:52 PM
bill06447's Avatar
bill06447
bill06447 is offline
Where/how did you mount the GM HEI module? ~Bill
  #120
Old 06-12-2014, 05:25 PM
Sean_Memphis
Used my TFI coil
Truck looks good!! I went w/ the DSII ICM. I'll have to post some new pics.
Quick Reply: Duraspark II Conversion - How To
