1996 f-150 Engine trouble - Ford Truck Enthusiasts Forums
Old 11-17-2010, 08:28 PM
klingel9066
klingel9066 is offline
klingel9066 is starting off with a positive reputation.
I've got a 1996 f-150 with the 5.8 engine. I've been having trouble with it cranking lately. Sometimes it'll just sit there and turn the engine like everything is ok but never crank. Other times it'll crank right up. It's not the fuel pump. What could cause it to turn over like that without cranking? Thanks
Old 11-17-2010, 08:33 PM
96ford250
96ford250 is offline
96ford250 is starting off with a positive reputation.
Its probly the IAC and or the throttle body clean them with some throttle body cleaner and it might fix the problem its kinda common
Old 11-18-2010, 09:09 AM
klingel9066
i don't know much about engines but since mine is carborated (?), then I don't have a throttle body do I? and what's the IAC?
Old 11-18-2010, 09:24 AM
EffunFiddy's Avatar
EffunFiddy
EffunFiddy is offline
EffunFiddy has a good reputation on FTE.EffunFiddy has a good reputation on FTE.
The IAC stands for Idle Air Control (correct me if I'm wrong) and it is mounted on the side of your intake, right on the side of the throttle body.
Google Image Result for http://www.supermotors.org/getfile/266545/fullsize/6%20Remove%20IAC%20Plug.JPG
The chap in this picture has his hand on the IAC. Let me know if the link doesn't work. I still don't know how to attach pictures. Quite often you can take the IAC off with two mounting bolts, you'll find that it's usually got a buildup of carbon inside. I sprayed mine out with throttle body cleaner and it solved the problem.
Old 11-18-2010, 09:32 AM
subford's Avatar
subford
subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
You say yours is a 1996 and is "carborated"?
This does not sound right, if it is carburated then no you do not have the throttle body like they are talking about.
Note, carburated engines did have throttle body at the bottom of the unit.
But I would think that your problem is not what they are talking about.
Sounds more like a Computer problem if the is a 1996 5.8L FI US engine.
Old 11-18-2010, 04:51 PM
EffunFiddy's Avatar
EffunFiddy
I don't know how I did it, but I must have read the post wrong. I missed the part where the problem was an intermittent one. I see what you mean now subford, an IAC wouldn't likely be an intermittent problem. Could it be the Ignition Control on the distributor?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
