Straight 6 revs way up upon start up! - Ford Truck Enthusiasts Forums
Old 11-17-2010, 03:29 PM
IDIDieselJohn's Avatar
IDIDieselJohn
IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
'88 F150 4.9L - 6
Just got done today putting back together the starter (was sticking on for a couple seconds after you let go of the key)
Cleaned it up, undented the small steel cover where it was sticking.
Now it works fantastic, but just like before, engine revs up a 'lil beyond 3000RPM as soon it fires for a couple seconds, then comes down to 1500 and eventually 700 when warmed up.
It revs up over 3000 every single time you fire it up, cold or warm!
Any pointers here? Sorry, major noob to these EFI Fords....
My other '89 Straight 6 starts great just like this one, and slowlly revs up to around 1500 for warm up.
Old 11-17-2010, 04:37 PM
rla2005's Avatar
rla2005
rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
I had a 1991 GMC S-15 a few years ago rev way up like that. It was an intermittent problem, but I finally traced it back to a bad Engine Coolant Temperature sensor. I used a meter to see what it's output signal was, turns out the value equated to a temperature reading of 75 degrees below zero (-75F).
The Ford PCM relies on the ECT just like the GM truck did. I saw your other post about your truck running cool and the white smoke. I would take a look to see what the ECT sensor is giving out as a feedback signal.
Old 11-17-2010, 04:41 PM
IDIDieselJohn
Where would the ECT be located?
Old 11-17-2010, 05:04 PM
rla2005's Avatar
rla2005
This should answer that question:
Old 11-17-2010, 05:20 PM
IDIDieselJohn
Thanks alot for the pic! I will have a look at it hopefully tomorrow and get back with results.
Old 11-18-2010, 08:21 AM
jas88's Avatar
jas88
jas88 is online now
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Mine does the same thing, it doesn't go to 3000 but maybe 2000-2500, and I have already replaced the ECT sensor and the ECU (for other reasons). Every so often it will stop doing it for a few days, then it comes back. I've kind of gotten used to it but I will be very interested what you find out.
Old 11-18-2010, 10:39 AM
hivoltj's Avatar
hivoltj
hivoltj is online now
hivoltj is gaining momentum as a positive member of FTE.
Check for vacuum leaks with some carb cleaner, or the IAC valve may be sticking.
8 times out of 10 with a Speed density setup that has idle problems it's a vacuum leak.
Old 11-18-2010, 01:52 PM
rla2005's Avatar
rla2005
Normally I would agree with that, but in this case the idle RPM appears to return to normal once the engine is warmed up. Could be a vacuum leak that seals up once the engine is up to temperature?
Old 11-18-2010, 02:47 PM
IDIDieselJohn
If it was a vacuum leak, wouldn't I hear a hissing sound? I have checked real quick for a leak and nothing.
It idles perfectlly fine, nice and smooth, just gives that huge rev every single time you fire it up.
I wouldn't bother with it if it would only do it when the engine is warmed up, but it does it all the time, even when dead cold.....I hate revving a dead cold engine!
And forgot to ask yesterday night, how do you test the ECT? Test light with key ON? or with a meter?
Today I decided to screw around with my weird electrical problem, all lights work good, but when the pull out the **** for night lights, the left turn signal stops working. Just goes on and stays on.
When the lights are off, key on, left turn signal works fine, but the roof lights and dash cluster lights flash along with it? The PO did one hellava electric work under the truck running from the fuse box, to rear harness. Even has a bunch of marrets along the wires....
Old 11-18-2010, 04:57 PM
rla2005's Avatar
rla2005
Ford Fuel Injection Engine Coolant Temperature Sensor (ECT)
Ryan has values in ohms and volts. I would just measure the voltage value when the engine is cold. That will be the dead give away if it measures out of whack.
As far as vacuum leaks go, no most of them do not exhibit a hissing noise.
Old 11-18-2010, 05:59 PM
IDIDieselJohn
Thanks alot for the link!
It is low on coolant tho.... so I guess I'll adress that before doing anything else.
frdf250
05-03-2017 06:11 AM
Algoa
17
10-06-2016 07:20 PM
Skydivelout
46
05-09-2016 09:52 PM
04redstroker
23
09-10-2013 11:51 AM
Saz221
1999 to 2016 Super Duty
05-26-2010 09:01 AM
Quick Reply: Straight 6 revs way up upon start up!
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
