71 f250 4x4 steering column rebuild some ?
#32
#33
#34
Is there only the bearing at the bottom and the clamp on the shaft...is there anything that keeps the bearing from pushing up in the column?
The pics are great!
If you look at the 2 pics I posted...can you tell me what the washer and threaded nipple are there for? Or is that macgyvering?
Thanks
The pics are great!
Thanks
#35
on
Steering & column
When I did my power steering conversion, I decided to knock all the old cracked plastic (like yours), off the wire frame & hub for the steering wheel. I found a suitable hardwood, and made the appropriate pieces. My wheel was 3 spoked, as my rig is a '67, and came with that wheel. It turned out really nice and was not too difficult. I will look on my computer later, and see if I can find some photos to post...
Baja
Baja
#36
#37
Quote.
I went through this a while back. From what I remember I had 2 different columns. Each had a different bearing at the bottom. One just had a bearing that fit into the plate welded to the bottom and the clamp just pushed the bearing into that plate. The other had a bearing with a piece of rubber around it and that pushed up into that plate but the seat in the plate was different than the other column so I couldn't use that bearing in the other column.
Hope I didn't mix you up.
#38
Quote.
Top bearing C3DZ-3517-B
Top bearing sleeve B1AZ-3518-A
Lower bearing F23Z-3517-B
Lower bearing sleeve C6TZ-3518-A
#39
Here's why you had trouble when trying to mix match.
2wd columns use the same upper and lower bearing (C3DZ-3517-A) and sleeve (B1AZ-3518-A). 4x4 uses the same upper bearing and sleeve as a 2wd.
BUT use a different lower bearing and sleeve. Here's the parts needed to rebuild the 4x4 column.
Top bearing F23Z-3517-B C3DZ-3517-A ~ Available from Ford
Top bearing sleeve B1AZ-3518-A ~ Available from Ford
Lower bearing F23Z-3517-B Available from Ford
Lower bearing sleeve C6TZ-3518-A Obsolete
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
#40
Awesome response Bill I was actually hoping you'd reply back. That's up to the next guy to figure out on finding the parts needed. I am grateful I got them. I wanted to clarify exactly what's needed for any confusion on parts between the 2wd and 4x4 since this thread is about the 4x4 column.
#41
I think that's all of the replaced part numbers.
Jmwinter
31
07-08-2020 03:41 PM
F-250 restorer
06-01-2016 07:04 PM
Mercmeister
15
01-29-2015 01:35 PM
NMFirstF2504X4
20
02-11-2014 10:47 AM
