1992 f250 460 efi wont start.
I am sure this has been covered, but I am at a total loss. It will start and run on starting fluid, has good spark, has 40 PSI at the rail, has 12v at red wire at injectors with the key on, attached noid light and I get a pulse but it is very weak, and checked resistance at the injectors and they are 14 ohms. I hope someone can help before I get full coverage and start a fire. I was going to replace the tps thinking that it might be reading clear flood mode, but realized that I wouldn't get pulse at injector, right? Also thought same about ignition module. If it's not working, no pulse right? The weird thing is I'm getting pulse but it is very weak. Please help I have spent days on this and am no closer than I was at the begining.
Try unplugging the MAP(electricly). Weak noid pulse is evident of a MAP that's giving the ECM incorrect BARO info. Check the center wire on the MAP. Should be around 158 HZ KOEO. Every 3 HZ or so going down equates to about 1000' in elevation. If this didn't make it start, unplugging the vaccum line on the MAP. Connect your mighty vac and draw about 10''. See if it starts then. If it does check your cranking vacuum. Needs to be at least 5''.
Ok, I think I may have it. I unplugged the tps thinking that maybe it was reading wot and in flooded mode. It started and ran for 2 sec. then died. Went to the parts store and had to order tps. Will have it tomorrow. This is the closest I've had it to starting yet. I will let you guys know what happens tomorrow.
I replaced the tps and nothing. I have the day off today and will try the map suggestions and the eec relay. Held a screwdriver to my ear and the injectors and they all seem to fire equally. changed all the plugs and they smell like gas after cranking. I just dont know. Compression is 120psi cold, as I cant get it to run to warm up.
I have a 1992 ford f super duty that ran fine 2 days ago and the other day went to get in it and it'll crank all day but won't start. I have fuel and I have spark there is just something going on that will not let the fuel pump kick on with the key but if i bypass it it kicks on i have been all throught this truck right down to the inertia switch and nothing has worked any ideas would greatly be appreciated.
I am not sure what you are saying.
You say you have spark and fuel and then you say the pump will not click on.
If you are saying when you turn on the key the pump will not start for one second and quit. But if you ground pin #6 of the self-test connector and turn on the key the pump will run.
If this is what you are saying you have either bad wiring from the self-test connector to the computer or a bad computer.
CMSRock
10-26-2021 04:29 PM
fusiondew
10-22-2020 06:51 AM
john starnes
29
08-16-2015 09:34 PM
dizzy01
05-13-2015 03:48 PM
