who told me these trucks wont catch fire from a fuel leak?
on
a friendly reminder to make sure when doing any kind of fuel mod...do it right the first time..
this guy was very lucky he was only in the house for a minute and that it was very small leak..any longer in the house or a bigger spray of fuel his truck would be gone..
Wow- today was my lucky day. Usually I start and drive off. Today, I started and went inside to get a new blade for a wiper, came out and noticed moderate amount of smoke coming from under the front of my Nov 1999 build F350. Shut it off, popped the hood, opened it and was very surprised to see a wee tiny fire burning behind the plastic fuel filter cover. I jumped up and was able to blow it out quickly (like a candle on a birthday cake). Below is a picture with labels...
The fire seemed to be related mostly to spilling fuel and a tab of hanging electrical tape...no other damage apparent. The fuel appeared to be leaking out from around the base of a white plug on the back of the fuel filter housing...my Chiltons is not clear, I think that this is the fuel heater...it is circled in the attached picture. The base of the white plug appears to have significant heat damage. Also, one of the terminals on the glow plug relay appears burned...this is also circled in the picture.
Any thoughts on this gentlemen? What is the white plug? Anyone had this problem? Recommendations? One relevant note is that I live off of the road system in rural Alaska and have no Ford diesel mechanic locally.
on
i took my bowl and all stock lines out of my truck...i have no o rings to let go and all my hoses have crimped ends...i dont fool around with fuel lines..lost a good friend that way....
Thanks for the post Ron. Went to town last night for some groceries and came back out to the smell of fuel and a very small puddle under the truck. Looked like leaking orings on my drain valve. I did notice that the fuel bowl heater plug was soaked. Gonna wash it off this morning and verify leak location.
That relay you have circled is your glow plug relay. If that outbound side is getting hot enought to roast the boot and do that, replace the relay. Although it could be as already said, a loose connection that is arching causing the excess heat. But that is the original relay... May as well get a better one in there. You can get a Stancor relay for about $25. And it will be alot stronger.
The Orings on the drain valve is a good place to start. Easy and cheap to fix too.
The example cited above was clipped from a post I did earlier this year on January 16 when my fuel bowl heater came loose. It shorted against the fuel filter housing causing the wire to the heater to heat up and melt through the plug where it goes through the housing. This resulted in a pressurized fuel release. All of this was replaced and is fine now.
This was not related in any way to a fuel system modification.
The original post with color pictures is here:
https://www.ford-trucks.com/forums/9...gine-fire.html
Thanks.
Thanks.
