LMC cab mounts, not happy!
Just got my new cab mounts installed on my 1970 ford crewcab. It wasn't a very good fit. It worked but not a nice clean install like I was hoping. I believe I will be going back into this down the road for sure. was having to do this and had to get done today. I guess this is a lesson learned. Lots of grinding and panel just didn't fit the btm of my cab.
i know exactly what your talking about not a good fit at all i just got done a hour ago welding the last of the cab mounts in my 71 f250 crew cab i will be going over this again to when i pull the frame from under it next summer i hope but had to get it done just like you did you have any pics of your project i been seeing alot of your posts and it got me anxious to see some of this work.
old crewcab stuff.
That's almost like I want my truck to be set up as my mounts took alittle work getting in I have about 6 inches on each side I have to go over when I pull the frame out next year I couldn't reach at the exhaust they will work but I will go with Dennis carpenter next time as these aren't as sturdy as id like them to be do you have power steering im looking for a donor 78 or 79 to swap axles and power steering from seeing if youve done it yet or are going to would be nice for some pics and info on the conversion I'll be posting some pics up when I get time to make a Photobucket account of my floors and mounts
cab mounts stuff
On the cab mounts for a 1970 ford crew cab. 49-8810 left, 49-8811rh. this is what is showing in the LMC book for my truck. Lots of grinding to get to the proper placement for cab to frame alignment. Once welded it in, just didn't lay in flat as i think it should. from a distance looks OK but I know its not my best work for sure. definetly would check into someone elses cab mounts if considering do the repair. I was in a time frame situation and had to get it done, its done. but slowly getting the cab where i want it.
I used the DC cab mounts they are ok the rubber is good its the bolts and pipes that kind of suck the 6 bolts they send are all the same length and are two long in 4 places work will in one so I had bought 4 more bolts and nuts that would work and look good.I bought them a few years back for my 78 and those were like the factory bottom was a washer with the nut built in.So some where they got cheap.
finally getting around to posting some pics of my install of the LMC cab mounts. sorry for the sloppy welding it hurts my eyes to see it but i was using a cheap flux core mig welder. its the only thing i had access to using.
<a href="http://s1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20restore/?action=view&current=ImportedPhotos000432.jpg" target="_blank"><img src="http://i1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20restore/ImportedPhotos000432.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20restore/?action=view&current=ImportedPhotos000472.jpg" target="_blank"><img src="http://i1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20restore/ImportedPhotos000472.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20restore/?action=view&current=ImportedPhotos00044.jpg" target="_blank"><img src="http://i1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20restore/ImportedPhotos00044.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20restore/?action=view&current=ImportedPhotos000452.jpg" target="_blank"><img src="http://i1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20restore/ImportedPhotos000452.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20restore/?action=view&current=ImportedPhotos000522.jpg" target="_blank"><img src="http://i1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20restore/ImportedPhotos000522.jpg" border="0" alt="Photobucket"></a>
the flux core wire actually gives a good hold on metal ive welded alot of things with it and has never failed yet. it's the cheap welder that is the problem in my case. but in the end nothing compairs to a good ole miller MIG welder with gas maybe that will be my gift to myself next year.
doesnt matter who you go with, its all chinese crap nowadays. even dennis carpenter has a page long disclaimer on their website explaining how tons of their parts have been outsourced. the government has prettymuch made it impossible for anybody to make an honest living anymore, and the american dream of getting somewhere in life, and one man working to support the family comfortably while the wife stays home, that is all gone, long gone.
