Code help needed
Old 01-26-2013, 12:16 PM
Quigles4's Avatar
Quigles4
Quigles4 is offline
Code help needed
I got some codes pulled for my 91 f250 351w. I got a 21-24 under "o" condition. All it says is that some sensors are out of range. They are sensors that have been replaced before. I just don't know what out of range means. Any help?
Old 01-27-2013, 05:26 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
A much better definition of codes here: Fuel Injection Technical Library » 2 Digit Self-test Codes 11-32
DTC 21: ECT out of self test range 0.3 to 3.7 volts.
DTC 24: ACT sensor out of self test range 0.3 to 3.7 volts.
The most common cause of those codes is not warming up the engine before running the Key On Engine Off (KOEO) tests.
DTC 22: MAP sensor out of self test range.
DTC 23: Closed throttle TPS voltage higher or lower than expected.
Your poor engine performance is probably related Code 22 and 23. If you have replace the MAP sensor and TPS before then it is time to start checking wires and signal output.
For reference:
Fuel Injection Technical Library » Engine Coolant Temperature Sensor (ECT)
Fuel Injection Technical Library » Air Charge Temperature (ACT)
Fuel Injection Technical Library » Manifold Absolute Pressure Sensor (MAP)
Fuel Injection Technical Library » Throttle Position Sensor (TPS)
Old 01-27-2013, 05:30 AM
rla2005's Avatar
rla2005
rla2005 is offline
You should also stick to one thread: https://www.ford-trucks.com/forums/1...nightmare.html
Old 01-27-2013, 08:18 AM
Quigles4's Avatar
Quigles4
Quigles4 is offline
What should I look for in the wires. And how should I go about testing the output. I'm not very experienced with automotive wiring at all
Old 01-27-2013, 09:49 AM
bashby's Avatar
bashby
bashby is offline
Clear the codes then check them again with the engine fully warmed up, no point in chasing a false code.
Old 01-27-2013, 10:27 AM
Quigles4's Avatar
Quigles4
Quigles4 is offline
Well I let it warm up and just got 22 and 23. When the motor is under load it sputters and bucks. I'm wondering if the problem is the map sensor or relates to it
Old 01-27-2013, 11:55 AM
bashby's Avatar
bashby
bashby is offline
Bad spark plug wires will cause a missfire under load. MAP sensor is probably the most important sensor and will cause sputtering. Are you seeing any black smoke from the tailpipe when it is sputtering?
Old 01-27-2013, 11:57 AM
Quigles4's Avatar
Quigles4
Quigles4 is offline
Yeah. It does that on idle
Old 01-27-2013, 12:28 PM
rla2005's Avatar
rla2005
rla2005 is offline
The links I posted before lists the expected values at different operating conditions. You will need a Voltmeter to test the TPS. Testing the MAP is a little more involved because the output is a frequency not a varying voltage. I have a Digital Voltmeter (DVM) that can measure voltage and frequency (as well as resistance).
As noted previously the MAP sensor is a key input to the PCM for controlling the engine and transmission, if it is an electronic controlled version such as an E4OD.
Old 01-27-2013, 12:29 PM
bashby's Avatar
bashby
bashby is offline
Probably a bad map. Sometimes they will run better with the map unplugged. The comp uses set values when it has no signal as opposed to it believing what the bad sensor is telling it.
Old 01-27-2013, 12:32 PM
Quigles4's Avatar
Quigles4
Quigles4 is offline
Ok I might try that. I have a zf5.
RadioControlGuy85
03-17-2024 12:27 PM
btypd
02-10-2014 11:43 PM
brcwelding
04-21-2013 05:57 PM
justin_brandstein
03-29-2009 07:39 PM
DaMole
05-31-2006 07:34 PM
Quick Reply: Code help needed
