Unplugged my EGR and check engine light?
Just an FYI...You do know that an aftermarket intake is a no no with a 6.0 right? As far as unpluging the EGR valve to make the truck run better, i'm not sure what you are wanting to get out of that? As far as running better, unless the valve is pluged up and not working correctly, you will not see any difference in the way it runs. Powerstroke is right if you do want that valve unpluged you will have to have custom tunning to turn off the cell. Also incase you haven't seen Cheezit, our friendly naborhood tech, has discovered that not having the valve pluged in effects the cooling fan operation. Somthing along the lines of it won't let the fan kick in all the way to full speed.
on
a little info on this.
basicly the non oem filters such as banks and aef flow more air at rpm's above 3500 rpm. this sounds great till you realize that only gives you 500 rpm of more air flow if your lucky. the air flow incress is only usefull when its in its power band. the 6.0 starts making power and torq at around 2k and is past peak at 3k.
the oem filter filters better then any filter out there you could by. the thing will hold about 3 lbs of dirt. were as the aftermarket tends to flow it. Compression ration being at 18:1 or something close to that dirt will very quickly dust an engine and turbo as well.
on
https://www.ford-trucks.com/forums/9...egr-valve.html
soem egr valve info for you too.
there are 2 techs in this thread, myself and matty. we had both discovered the same issue.
kjgibson2
117
10-29-2017 10:22 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
01-16-2017 05:04 PM
ericbskis
07-19-2014 10:00 AM
