Rear axle U-bolt part #
Old Nov 11, 2010 | 10:08 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
I am FINALLY getting around to installing my RAS on my stock 05 Excursion. I ordered replacement ubolts and received them as part number f81Z-5705-BB. Trouble is, they are about 2" longer than the stock ubolts. Did I get the wrong ubolts? Will these work? I am concerned that the exta bolt length will hit something up top.
Old Nov 12, 2010 | 11:26 AM
Stewart_H's Avatar
Stewart_H
Just cut them with a sawzall to the length you want.
Stewart
Old Nov 12, 2010 | 11:44 AM
Misky6.0's Avatar
Misky6.0
Stewart
Hey tinkerer,
Although I haven't actually done this, I "think" you should put the
nuts on FIRST then cut off the bolts to length. Then back-off the nuts
to clean up the threads. If you cut the bolts first, it's sometimes
tough to start the nuts.
Old Nov 12, 2010 | 11:47 AM
Stewart_H's Avatar
Stewart_H
Originally Posted by Misky6.0
Hey tinkerer,
Yeah, I probably shouldn't assume that was a "given."
Install first to make sure you know the correct length to cut off.
Stewart
Old Nov 12, 2010 | 12:10 PM
FICMrepair.com
Former Vendor
Yeah, I thought about that, but got concerned over rust. I suppose I could cut them off and then paint the cut edge with some Rust Oleum.
johnnydevil55
16
Feb 7, 2016 07:41 PM
DHamSTER
Oct 9, 2014 04:45 AM
AF_MAC
Sep 15, 2014 08:20 AM
Pappys53
May 26, 2013 06:07 PM
viperbluelx
Jul 8, 2007 04:54 PM
