new superduty owner, changing oils questions
Just got a 04 250 cc 4x4 5.4 auto 161,000 miles.
I was think of changing the front and rear diff, tranny and transfer case oil. Do you think this is a good idea? Is theri any thing special about changing the oil or the oil itself? I already changed the engine oil used motorcraft 5-20.
thanks
thanks
Here is some great how-to articles. I think all these links would apply to your truck but you may find some things not the same.
Rear diff: http://guzzle.rbmicro.com/rdiff.html
Front diff: http://guzzle.rbmicro.com/fdiff.html
Transfer box: http://guzzle.rbmicro.com/transfer.html
Transmission: https://www.ford-trucks.com/article/...nsmission.html
Yes, I always change all the fluids when I purchased used vehicles. It gives you a baseline for future maintenance and eliminates any question about what was previously done.
Don't forget your coolant and brake fluid.
Use fluids recommended in your owners manual. Here is a link to an electronic copy of that manual, if you don't have one.
http://www.analogstereo.com/pdf/om/f...anual_2004.pdf
