Block heater temps... by the hour.
This morning I plugged the block heater in. My Scangauge read 39 degrees.
1 hour later it was 80 degrees.
2 hours later was 94 degrees.
3 hours later it was 103 degrees.
4 hours later it was 110 degrees.
5 hours later it was 116 degrees.
Yes, 39 isn't that cold to start, but was interesting to see that it went from 39 to 80 in an hour.
Currently my oil temp in hour 3 is 77 degrees. It was 40 at starting point.
Oil temp after 4 hours was 91 degrees.
I would be curios ad to the location of the temp sensor in relation to block hearer location.
If they are both on the same side then after 1 hour perhaps only 1/2 the coolant is at 80 & the other 1/2 is much lower. Our is it going to mix pretty fast regardless?
Good info as I was just thinking about plugging her in and wondered about for how long.
FYI since I had my comp reflashed it sure starts and runs nice when cold!
each truck may very a little on warm up time.I like your method of time and temp. I always try to plug it in for the least amount of time possible. electric heating elements dont seam to heat as well over time. so in an attempt to make it last I plug it into a timmer and let it go anywhere from 2-4 hours depending on temps.It doesnt look to bad to change either. Its nice to get in a truck thats a little warm my problem is when it gets wet weather my cord trips the breaker always seams to be a fight for power. has anyone moved the plug in for the heater. if i let it hang it almost always trips out. And whats even better than that is when the old lady takes it and forgets to unplug it . I am thinking of moving mine somewhere by the driver door I just think it almost needs to be obvious its plugged in somewhere the driver cant miss it getting in the truck. a oil pan heater would be nice alot of oil thats still cold at startup regardless of coolant temp.
Oh come on. Nothing like a nice clear day, the sun reflecting off of the snow until your eyes hurt and 40 below.
In all seriousness though, I'm gonna have to try this test. My Edge can give me those readings.
PS I would rather have -40 and sunny, than -1 and overcast with high humidity.
GOtta love the northland.....
Absolutely! I grew up in NJ now live in FL. The humidity makes it "feel"
so much colder because of how much faster the moisture wicks the
heat from your skin.
I've been in Colorado @ 10* F and it's felt warmer than FL @ 45*
Of course, I've been in Montana @ -40* and that was C O L D.
I just ordered that same plug a couple days ago, hoping it might be in the mailbox when i get home. Do you have any pictures of the plug on your truck, i'm just trying to get ideas for when i do my install, hopefully this weekend.
