65 F100 Steering wheel/turn signal
The indicator light works fine but the flasher is faint so perhaps if I replace the flasher unit it may increase the sound. Be that as it may, have to replace the lower shaft bearing anyhow, sounds like pistons swapping holes and shaft is increasingly getting sloppy. Seem to recall it being mentioned the lower bearing race is welded/tacked onto the steering shaft and don't recall doing that I reconditioned the steering column many, many yrs. ago. Anyhow, purchased the kit from p/n Bill (ND) posted now just matter of finding the time.
65 turn signal wire?
I just replaced the turn signal switch on my '65 F100 CC. The wiring under the dash was a mess, I had no real reference to go by where all the wires are supposed to go. I've traced and figured out most of them.
Does anyone know where the solid green wire coming off the switch is suppose to go to? It comes from the same location in the center of the switch pivot as the blue wire. I know the blue wire is to send power into the switch... but what about the green wire? Is this suppose to have power coming out?
thanx, max
thanx, max
The following users liked this post:
Mdc9966
12-05-2016 02:41 PM
alecs
09-16-2016 04:58 PM
jason90f150
04-19-2016 03:46 PM
