Cab On Engine Removal and Head Gaskets
#32
Engine Removal Day 4. Today took longer then I had expected. I though I was going to just pull of the bed plate. The bed plate gasket is tied into the engine back cover which is connect to the HPOP cover which all had to come off. The engine was already on the engine stand so I was juggling the engine from engine stand to engine hoist to get off the flywheel, backcover, bed plate and HPOP cover. Taking a few days off, cleaning parts, heads to the machine shop, need to order gaskets for the whole engine, did not realize I was going to be tearing the engine down to this point. I will continue with more pics when I get everything ready to start putting it all back together.
<center>
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%20Day%204/?action=view¤t=IMG_2847.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%20Day%204/IMG_2847.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%20Day%204/?action=view¤t=IMG_2848.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%20Day%204/IMG_2848.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%20Day%204/?action=view¤t=IMG_2849.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%20Day%204/IMG_2849.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%20Day%204/?action=view¤t=IMG_2850.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%20Day%204/IMG_2850.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%20Day%204/?action=view¤t=IMG_2851.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Engine%20Removal/Engine%20Removal%20Day%204/IMG_2851.jpg" border="0" alt="Photobucket"></a><br /><br />
</center>
<center>
</center>
#35
#36
Those who do this every single day for a living should be able to do it blind folded with one arm and a leg tied behind their back.
#38
use grey silicon (use only grey ford part number is ta-29) at the t-joints of the front and rear cover as well as the hpop cover. the bed plate uses an Anaerobic Gasket Maker and lay.... lay a thin bead on both the block and bed plate, then set the worm gasket in the bed plate and install the bed plate on the block.
just fair warning some of the specs in the workshop book way be outdated. the online book is best. the second best would be the last release of the cd/dvd
https://www.ford-trucks.com/forums/974064-my-ride.html dont know if these pics will help you are not as well.
#40
thankyou very much !!!Do I need to put to put the form gasket on the block as well.I really appreciate the help,getting ready to put it back together and this is the part that bothers me most,dont want any leaks..
