7.3 IDI Oil Cooler
If you have them swapping liquids like you describe, it's a pretty safe bet it's the cooler. Either the o-rings, gasket or the "log" itself. You can get at it through the wheel well and from underneath. I remove the 2 motor mount bolts and jack the engine up and the cooler assembly will come right out the bottom towards the rear.
O-rings are Ford or International only. The gaskets you can get anywhere for around $4.
The red ends tube on my engine here is the cooler.
Thanks grey. I got it down and found that both the oil & anti-freeze side was just about completely plugged. As with some small metal pieces, both steel & aluminum. Flushed everything out and put back in. I have a haynes manual for this truck, but it does not list the torque specs for the mounting bolts.(nor does it even list an oil cooler for this truck,dang aftermarket books). Does anyone know what these torque specs are, I would appreciate it. Thanx!!!
I really hope you replaced the o-rings while you had the cooler apart, else it may never seal properly again. I have a junkyard cooler laying around here waiting on a rebuild, I get it rebuilt then just swap it in my truck in a few hours.
Also, I've seen it mentioned to not use gaskets where the cooler headers mate to the engine block.
U.S. BOLT GRADES
___________SAE 2__________SAE 5______SAE 7______SAE 8_____CAP SCREW
I.D.______No markings_______3 lines_____5 lines______6 lines_____Allen head
__________________________________________________ ________________________________________
<TABLE border=1 cellSpacing=0 borderColorLight=#00ffff borderColorDark=#0000ff cellPadding=0 width="61%" height=502><TBODY><TR bgColor=blue><TD bgColor=#000000 height=60 colSpan=12>U.S. BOLT TORQUE SPECIFICATIONS
Torque in pounds-foot
</TD></TR><TR bgColor=blue><TD height=18 width="6%">Grade</TD><TD height=18 width="9%"></TD><TD height=18 width="5%" align=middle>[************]2[/COLOR]</TD><TD height=18 width="7%" align=middle>[************]2[/COLOR]</TD><TD bgColor=purple height=18 width="5%" align=middle>[************]5[/COLOR]</TD><TD bgColor=purple height=18 width="7%" align=middle>[************]5[/COLOR]</TD><TD height=18 width="5%" align=middle>[************]7[/COLOR]</TD><TD height=18 width="7%" align=middle>[************]7[/COLOR]</TD><TD bgColor=purple height=18 width="5%" align=middle>[************]8[/COLOR]</TD><TD bgColor=purple height=18 width="7%" align=middle>[************]8[/COLOR]</TD><TD height=18 width="12%">[************]Socket head
cap screw[/COLOR]</TD><TD height=18 width="14%">[************]Socket head
cap screw[/COLOR]</TD></TR><TR bgColor=yellow><TD height=18 width="6%">Bolt
Dia.</TD><TD height=18 width="9%">Thread
per inch</TD><TD height=18 width="5%">Dry</TD><TD height=18 width="7%">Oiled</TD><TD height=18 width="5%">Dry </TD><TD height=18 width="7%">Oiled</TD><TD height=18 width="5%">Dry</TD><TD height=18 width="7%">Oiled</TD><TD height=18 width="5%">Dry</TD><TD height=18 width="7%">Oiled</TD><TD height=18 width="12%" align=middle>Dry </TD><TD height=18 width="14%" align=middle>Oiled</TD></TR><TR bg************><TD height=20 width="6%">1/4</TD><TD height=20 width="9%">20</TD><TD height=20 width="5%">4</TD><TD height=20 width="7%">3</TD><TD height=20 width="5%">8</TD><TD height=20 width="7%">6</TD><TD height=20 width="5%">10</TD><TD height=20 width="7%">8</TD><TD height=20 width="5%">12</TD><TD height=20 width="7%">9</TD><TD height=20 width="12%" align=middle>14</TD><TD height=20 width="14%" align=middle>11</TD></TR><TR bg************><TD height=20 width="6%">1/4</TD><TD height=20 width="9%">28</TD><TD height=20 width="5%">6</TD><TD height=20 width="7%">4</TD><TD height=20 width="5%">10</TD><TD height=20 width="7%">7</TD><TD height=20 width="5%">12</TD><TD height=20 width="7%">9</TD><TD height=20 width="5%">14</TD><TD height=20 width="7%">10</TD><TD height=20 width="12%" align=middle>16</TD><TD height=20 width="14%" align=middle>13</TD></TR><TR bgColor=aqua><TD bgColor=#f0f0f0 height=20 width="6%">5/16</TD><TD bgColor=#f0f0f0 height=20 width="9%">18</TD><TD bgColor=#f0f0f0 height=20 width="5%">9</TD><TD bgColor=#f0f0f0 height=20 width="7%">7</TD><TD bgColor=#f0f0f0 height=20 width="5%">17</TD><TD bgColor=#f0f0f0 height=20 width="7%">13</TD><TD bgColor=#f0f0f0 height=20 width="5%">21</TD><TD bgColor=#f0f0f0 height=20 width="7%">16</TD><TD bgColor=#f0f0f0 height=20 width="5%">25</TD><TD bgColor=#f0f0f0 height=20 width="7%">18</TD><TD bgColor=#f0f0f0 height=20 width="12%" align=middle>29</TD><TD bgColor=#f0f0f0 height=20 width="14%" align=middle>23</TD></TR><TR bgColor=aqua><TD bgColor=#f0f0f0 height=20 width="6%">5/16</TD><TD bgColor=#f0f0f0 height=20 width="9%">24</TD><TD bgColor=#f0f0f0 height=20 width="5%">12</TD><TD bgColor=#f0f0f0 height=20 width="7%">9</TD><TD bgColor=#f0f0f0 height=20 width="5%">19</TD><TD bgColor=#f0f0f0 height=20 width="7%">14</TD><TD bgColor=#f0f0f0 height=20 width="5%">24</TD><TD bgColor=#f0f0f0 height=20 width="7%">18</TD><TD bgColor=#f0f0f0 height=20 width="5%">29</TD><TD bgColor=#f0f0f0 height=20 width="7%">20</TD><TD bgColor=#f0f0f0 height=20 width="12%" align=middle>33</TD><TD bgColor=#f0f0f0 height=20 width="14%" align=middle>26</TD></TR><TR bg************><TD height=20 width="6%">3/8</TD><TD height=20 width="9%">16</TD><TD height=20 width="5%">16</TD><TD height=20 width="7%">12</TD><TD height=20 width="5%">30</TD><TD height=20 width="7%">23</TD><TD height=20 width="5%">40</TD><TD height=20 width="7%">30</TD><TD height=20 width="5%">45</TD><TD height=20 width="7%">35</TD><TD height=20 width="12%" align=middle>49</TD><TD height=20 width="14%" align=middle>39</TD></TR><TR bg************><TD height=20 width="6%">3/8</TD><TD height=20 width="9%">24</TD><TD height=20 width="5%">22</TD><TD height=20 width="7%">16</TD><TD height=20 width="5%">35</TD><TD height=20 width="7%">25</TD><TD height=20 width="5%">45</TD><TD height=20 width="7%">35</TD><TD height=20 width="5%">50</TD><TD height=20 width="7%">40</TD><TD height=20 width="12%" align=middle>54</TD><TD height=20 width="14%" align=middle>44</TD></TR><TR bgColor=aqua><TD bgColor=#e8e8e8 height=20 width="6%">7/16</TD><TD bgColor=#e8e8e8 height=20 width="9%">14</TD><TD bgColor=#e8e8e8 height=20 width="5%">24</TD><TD bgColor=#e8e8e8 height=20 width="7%">17</TD><TD bgColor=#e8e8e8 height=20 width="5%">50</TD><TD bgColor=#e8e8e8 height=20 width="7%">35</TD><TD bgColor=#e8e8e8 height=20 width="5%">60</TD><TD bgColor=#e8e8e8 height=20 width="7%">45</TD><TD bgColor=#e8e8e8 height=20 width="5%">70</TD><TD bgColor=#e8e8e8 height=20 width="7%">55</TD><TD bgColor=#e8e8e8 height=20 width="12%" align=middle>76</TD><TD bgColor=#e8e8e8 height=20 width="14%" align=middle>61</TD></TR><TR bgColor=aqua><TD bgColor=#e8e8e8 height=20 width="6%">7/16</TD><TD bgColor=#e8e8e8 height=20 width="9%">20</TD><TD bgColor=#e8e8e8 height=20 width="5%">34</TD><TD bgColor=#e8e8e8 height=20 width="7%">26</TD><TD bgColor=#e8e8e8 height=20 width="5%">55</TD><TD bgColor=#e8e8e8 height=20 width="7%">40</TD><TD bgColor=#e8e8e8 height=20 width="5%">70</TD><TD bgColor=#e8e8e8 height=20 width="7%">50</TD><TD bgColor=#e8e8e8 height=20 width="5%">80</TD><TD bgColor=#e8e8e8 height=20 width="7%">60</TD><TD bgColor=#e8e8e8 height=20 width="12%" align=middle>85</TD><TD bgColor=#e8e8e8 height=20 width="14%" align=middle>68</TD></TR><TR bg************><TD height=20 width="6%">1/2</TD><TD height=20 width="9%">13</TD><TD height=20 width="5%">38</TD><TD height=20 width="7%">31</TD><TD height=20 width="5%">75</TD><TD height=20 width="7%">55</TD><TD height=20 width="5%">95</TD><TD height=20 width="7%">70</TD><TD height=20 width="5%">110</TD><TD height=20 width="7%">80</TD><TD height=20 width="12%" align=middle>113</TD><TD height=20 width="14%" align=middle>90</TD></TR><TR bg************><TD height=20 width="6%">1/2</TD><TD height=20 width="9%">20</TD><TD height=20 width="5%">52</TD><TD height=20 width="7%">42</TD><TD height=20 width="5%">90</TD><TD height=20 width="7%">65</TD><TD height=20 width="5%">100</TD><TD height=20 width="7%">80</TD><TD height=20 width="5%">120</TD><TD height=20 width="7%">90</TD><TD height=20 width="12%" align=middle>126</TD><TD height=20 width="14%" align=middle>100</TD></TR><TR bgColor=aqua><TD bgColor=#e8e8e8 height=20 width="6%">9/16</TD><TD bgColor=#e8e8e8 height=20 width="9%">12</TD><TD bgColor=#e8e8e8 height=20 width="5%">52</TD><TD bgColor=#e8e8e8 height=20 width="7%">42</TD><TD bgColor=#e8e8e8 height=20 width="5%">110</TD><TD bgColor=#e8e8e8 height=20 width="7%">80</TD><TD bgColor=#e8e8e8 height=20 width="5%">135</TD><TD bgColor=#e8e8e8 height=20 width="7%">100</TD><TD bgColor=#e8e8e8 height=20 width="5%">150</TD><TD bgColor=#e8e8e8 height=20 width="7%">110</TD><TD bgColor=#e8e8e8 height=20 width="12%" align=middle>163</TD><TD bgColor=#e8e8e8 height=20 width="14%" align=middle>130</TD></TR><TR bgColor=aqua><TD bgColor=#e8e8e8 height=20 width="6%">9/16</TD><TD bgColor=#e8e8e8 height=20 width="9%">18</TD><TD bgColor=#e8e8e8 height=20 width="5%">71</TD><TD bgColor=#e8e8e8 height=20 width="7%">57</TD><TD bgColor=#e8e8e8 height=20 width="5%">120</TD><TD bgColor=#e8e8e8 height=20 width="7%">90</TD><TD bgColor=#e8e8e8 height=20 width="5%">150</TD><TD bgColor=#e8e8e8 height=20 width="7%">110</TD><TD bgColor=#e8e8e8 height=20 width="5%">170</TD><TD bgColor=#e8e8e8 height=20 width="7%">130</TD><TD bgColor=#e8e8e8 height=20 width="12%" align=middle>181</TD><TD bgColor=#e8e8e8 height=20 width="14%" align=middle>144</TD></TR><TR bg************><TD height=20 width="6%">5/8</TD><TD height=20 width="9%">11</TD><TD height=20 width="5%">98</TD><TD height=20 width="7%">78</TD><TD height=20 width="5%">150</TD><TD height=20 width="7%">110</TD><TD height=20 width="5%">190</TD><TD height=20 width="7%">140</TD><TD height=20 width="5%">220</TD><TD height=20 width="7%">170</TD><TD height=20 width="12%" align=middle>230</TD><TD height=20 width="14%" align=middle>184</TD></TR><TR bg************><TD height=20 width="6%">5/8</TD><TD height=20 width="9%">18</TD><TD height=20 width="5%">115</TD><TD height=20 width="7%">93</TD><TD height=20 width="5%">180</TD><TD height=20 width="7%">130</TD><TD height=20 width="5%">210</TD><TD height=20 width="7%">160</TD><TD height=20 width="5%">240</TD><TD height=20 width="7%">180</TD><TD height=20 width="12%" align=middle>255</TD><TD height=20 width="14%" align=middle>204</TD></TR><TR bgColor=aqua><TD bgColor=#e8e8e8 height=20 width="6%">3/4</TD><TD bgColor=#e8e8e8 height=20 width="9%">10</TD><TD bgColor=#e8e8e8 height=20 width="5%">157</TD><TD bgColor=#e8e8e8 height=20 width="7%">121</TD><TD bgColor=#e8e8e8 height=20 width="5%">260</TD><TD bgColor=#e8e8e8 height=20 width="7%">200</TD><TD bgColor=#e8e8e8 height=20 width="5%">320</TD><TD bgColor=#e8e8e8 height=20 width="7%">240</TD><TD bgColor=#e8e8e8 height=20 width="5%">380</TD><TD bgColor=#e8e8e8 height=20 width="7%">280</TD><TD bgColor=#e8e8e8 height=20 width="12%" align=middle>400</TD><TD bgColor=#e8e8e8 height=20 width="14%" align=middle>320</TD></TR><TR bgColor=aqua><TD bgColor=#e8e8e8 height=20 width="6%">3/4</TD><TD bgColor=#e8e8e8 height=20 width="9%">16</TD><TD bgColor=#e8e8e8 height=20 width="5%">180</TD><TD bgColor=#e8e8e8 height=20 width="7%">133</TD><TD bgColor=#e8e8e8 height=20 width="5%">300</TD><TD bgColor=#e8e8e8 height=20 width="7%">220</TD><TD bgColor=#e8e8e8 height=20 width="5%">360</TD><TD bgColor=#e8e8e8 height=20 width="7%">280</TD><TD bgColor=#e8e8e8 height=20 width="5%">420</TD><TD bgColor=#e8e8e8 height=20 width="7%">320</TD><TD bgColor=#e8e8e8 height=20 width="12%" align=middle>440</TD><TD bgColor=#e8e8e8 height=20 width="14%" align=middle>350</TD></TR><TR bg************><TD height=20 width="6%">7/8</TD><TD height=20 width="9%">9</TD><TD height=20 width="5%">210</TD><TD height=20 width="7%">160</TD><TD height=20 width="5%">430</TD><TD height=20 width="7%">320</TD><TD height=20 width="5%">520</TD><TD height=20 width="7%">400</TD><TD height=20 width="5%">600</TD><TD height=20 width="7%">460</TD><TD height=20 width="12%" align=middle>640</TD><TD height=20 width="14%" align=middle>510</TD></TR><TR bg************><TD height=18 width="6%">7/8</TD><TD height=18 width="9%">14</TD><TD height=18 width="5%">230</TD><TD height=18 width="7%">177</TD><TD height=18 width="5%">470</TD><TD height=18 width="7%">360</TD><TD height=18 width="5%">580</TD><TD height=18 width="7%">440</TD><TD height=18 width="5%">660</TD><TD height=18 width="7%">500</TD><TD height=18 width="12%" align=middle>700</TD><TD height=18 width="14%" align=middle>560</TD></TR><TR bgColor=aqua><TD bgColor=#e8e8e8 height=18 width="6%">1</TD><TD bgColor=#e8e8e8 height=18 width="9%">8</TD><TD bgColor=#e8e8e8 height=18 width="5%">320</TD><TD bgColor=#e8e8e8 height=18 width="7%">240</TD><TD bgColor=#e8e8e8 height=18 width="5%">640</TD><TD bgColor=#e8e8e8 height=18 width="7%">480</TD><TD bgColor=#e8e8e8 height=18 width="5%">800</TD><TD bgColor=#e8e8e8 height=18 width="7%">600</TD><TD bgColor=#e8e8e8 height=18 width="5%">900</TD><TD bgColor=#e8e8e8 height=18 width="7%">680</TD><TD bgColor=#e8e8e8 height=18 width="12%" align=middle>980</TD><TD bgColor=#e8e8e8 height=18 width="14%" align=middle>780</TD></TR><TR bgColor=aqua><TD bgColor=#e8e8e8 height=18 width="6%">1</TD><TD bgColor=#e8e8e8 height=18 width="9%">12</TD><TD bgColor=#e8e8e8 height=18 width="5%">350</TD><TD bgColor=#e8e8e8 height=18 width="7%">265</TD><TD bgColor=#e8e8e8 height=18 width="5%">710</TD><TD bgColor=#e8e8e8 height=18 width="7%">530</TD><TD bgColor=#e8e8e8 height=18 width="5%">860</TD><TD bgColor=#e8e8e8 height=18 width="7%">666</TD><TD bgColor=#e8e8e8 height=18 width="5%">990</TD><TD bgColor=#e8e8e8 height=18 width="7%">740</TD><TD bgColor=#e8e8e8 height=18 width="12%" align=middle>1060</TD><TD bgColor=#e8e8e8 height=18 width="14%" align=middle>845</TD></TR></TBODY></TABLE>
Ok I have rebuilt the oil cooler as you all have seen. because of other more pressing things at work, I have not done anything but fill the radiator and put oil back into it. As I went back to it today, the oil was high and the water went low, just sitiing there without running it. It was over the course of 2 days and this happened. Tried to turn the motor over, and it wouldn't turn. Sounds like it was fluid locked. Guess I will have to tear it down and check further. Will do a leak down test 1st tho, I guess,lol. Thank god I go on vacation tomarrow!! Wont have to look at this truck for the next 2 weeks. Thanx to all who have given me advice on this rig.
Hello all. I know its been awhile, but I'm back to my project truck. I pulled the glow plugs, and the #4 cylinder was full of water. I yanked the motor and tore off the heads. The head gasket doesn't look to old, so I'm assuming someone has been in there recently. There was no visible signs of the gasket going bad, so I'm gonna have the heads sent out to see if they are cracked. If they turn out ok, I guess I would have to assume I have a cracked block. If so I will be in the market for another motor. Are these 7.3's prone to cracking blocks when overheated, or maybe someone didnt put anti-freeze in it and put block seal in it just to get it sold. Off to the machine shop I go!!
If so, your options are to sleeve it, if you can find a machine shop to do it right and warranty it OR find another block/engine and try again.
Frank250Tank
12-02-2016 07:55 AM
ProjectToyHauler
10-03-2016 05:39 PM
Goob
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
01-30-2012 08:57 PM
