VIN number dimlema
VIN number dimlema
Well i am back with another question.
From appearance my truck is a 1969 f250 4x4 Front dana 44 and rear dana 60 and dana a dana 24 transfer case. The truck is Red and white in color with the ranger package, it also has what appears to be a factory AC setup in the cab and an AC compressor under the hood.
There are two VIN taggs on the driver side door, there is one rivetted on the door and one screwed on the door.
The rivetted and titled is (F25HRF31907) and the one screwed on the door is (F26YRN60969).
Can someone please decode both for me?
Which is the more desireable truck, I dont know why there would be 2 vin plates.
When i purchased the truck it had Alaska license plates, i am not sure if this helps at all.
on
VIN number dimlema
69 F250??? The plot thickens Check out these VIN's.
Results for VIN#: F25HRF31907
Model Year: 69 (Edited in from 79 )
Series: F250 - 4x2 Pickup
Engine: 8 Cyl, 351ci (5.8L) 2bbl
Assembly Plant: San Jose
Results for VIN#: F26YRN60969
Model Year: 72
Series: F250 - 4x4 Pickup
Engine: 8 Cyl, 360ci, 2bbl
Model Year: 72
VIN number dimlema
My 1971 Ford owner's manual states that Ford stamped the VIN into the right frame side rail. On 4x4 it is located "8 inches from the front of the frame rail". On 4x2 it is "24 inches in front of the first body outrigger". Maybe that number will match one of your body VINs.
VIN number dimlema
VIN number dimlema
I tried to find my VIN on the frame with no luck. As an F250 4x4, I looked thoroughly around 8" from the front on the right frame rail. I am assuming right means passenger side (checked drivers side too, but nothing there either). Just in case I somehow have a 2x4 frame, I also check 24" in front of the first outrigger too. Nothing there. Looked on top of frame under passenger seat area as well - nothing. All I've gotten for my effort are some clean frame rail sections. Did Ford always stamp the frame?
While we're talking VIN, from the door and various paperwork my VIN is F26YRK03883. That appears to decode appropriately to a '71 F250 4x4 made in San Jose. I'm not sure about the rest though if anyone can clarify:
wheel base 131 - ok it's a longbed
color K - anyone know what color this is (should be green)
Body 6 - standard cab I'm assuming
Axle 4 - If we're talking front it's got a Dana 44 6CF - do I have a match?
Trans A - ok, NP 435
Axle 24 - if we're talking rear it's got a Dana 60. Match?
Appreciate any and all info.
VIN number dimlema
sasquatchmystery
04-04-2014 11:49 AM
sasquatchmystery
04-02-2014 11:21 AM
andy_flipper
07-17-2006 10:40 PM
