Just bought an '08 Escape
well....check engine light is on...code is P0455
Evaporative Emission Control System Leak Detected (no purge flow or large leak)
any idears?
troubleshooting tips?
already know the charcoal canister is going to run about $120 3-5 days from Ford...not 100% sure thats the problem tho....
any help'd be preciated
any idears?
You may have a leak, but doubt is the charcoal canister causing the problem, at least not in an 08 with only 78K.
I have a 2003 with 123K never had that problem. That charcoal canister should last the life of the vehicle baring that some other malfunction caused it to go bad.
