temp sender
Old 11-05-2010, 09:14 PM
our83's Avatar
our83
our83 is offline
temp sender
Anyone know for certain ?? Is a 72 Cleveland temp sender electrically compatable with the 1966 Ranchero dash. ???
Old 11-06-2010, 11:24 AM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
All the old Ford gauges used 10-73 ohm operating range. Fuel, oil pressure, temp makes no diff. Only diff in senders would be for either mechanical gauge or idiot light.
Old 11-06-2010, 01:48 PM
our83's Avatar
our83
our83 is offline
Temp sender
Thanks GFW1985. Where did you find the source of info. ?? Can I bench test senders to determine the resistance ? If so, How.
Old 11-06-2010, 02:51 PM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
Ohmeter. You can check the resistance between the wire term post and ground with still in vehicle. You should see it change as temp heats up. 73 ohms would be cold and resistance will drop as it heats up. Grounding the senders wire will peg the gauge to check that portion of the circuit. My source is restoring these old vehicles for the last ten years. Mainly 66-77 year range. Electrical gauges are mostly the same, just different faces and type of sender. Ford used one standard, Chev another etc. All the Ford gauges can be checked by grounding the sender wire, just not for too long, as they have an IVR, instrument voltage regulator, supplying voltage to them. The idiot light senders just supply voltage to the light when the senders value reaches a certain point, a switch for all entensive purposes.
Old 11-06-2010, 08:33 PM
our83's Avatar
our83
our83 is offline
temp sender
Thanks again. I did test in the manner indicated. I was not able to come up with 73 in fact the cold readings were more like 0.46. However I checked just after the engine started warming and got 62. Further along it got lower and finially came in at 10.3 at 179 degrees (in tank). Now if I only knew where the needle is supposed to point I'll have it made.
Thanks again, Ken Liden
Old 11-07-2010, 06:06 AM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
Thats the kicker. They weren't known to be overly accurate to start with. Better than idiot light, but not as good as mechanical gauges.
kabcpapc
Modular V8 (4.6L, 5.4L)
09-06-2014 05:35 PM
snowdog79
01-23-2014 10:28 PM
reamer
02-07-2005 09:42 PM
286merc
10-28-2002 07:41 AM
Superdave
10-18-1999 12:33 AM
Quick Reply: temp sender
