Coolant leak
02-19-2013, 05:52 PM
on
Coolant leak
I have a small coolant leak on my 7.3, I kinda thought it could be a bad seal on water pump or seal around it. Someone said today that the 7.3 has a pressure relief type deal that releases water due to pressure build up. Is he full of s or is there a chance he knows what he is talking about?
02-19-2013, 10:55 PM
Is your leak coming from behind the water pump pulley? If so its time for a new pump.
Maybe your friend was talking about the weep hole.
02-20-2013, 05:52 AM
Most vehicles release coolant when too much pressure builds up. Aside from air cooled engines, I cannot think of a vehicle that does not have some sort of pressure relief in the cooling system.
02-20-2013, 09:42 AM
on
I see some coolant up near the water pump. Not a lot but it is wet.
02-20-2013, 10:47 AM
I'd first recommend checking to make sure the thermostat housing is not leaking, then also checking to make sure the tank isn't cracked.
02-20-2013, 04:05 PM
on
Thanks for the advice everyone.
VaFordman26
04-14-2014 09:58 PM
65F100390
11-05-2010 04:53 PM
78f3504x4
06-03-2010 10:05 AM
SouthernBlues
01-24-2009 04:03 PM
JUMBO_UTE
02-08-2006 04:32 PM
