ats turbo on 92 f-250
i have a question on the nonwastgated ats turbo i ran this turbo on my 73 f-250 until i upgraded to the 96 powerstroke and i ran a manual, i am working on putting it on my dads 92 f-250 auto and i noticed that the tranny dipstick comes up the back of the passenger cylinder head and looks like it will be in the way of the up-pipe and down pipe cause both run up the passenger side of the tranny, do i need to get a different tranny dipstick tube or will this one work and it will be a tight fit.
the non wastgated turbo sides right behind the intake and the compreeor housing is on the driver side the intake and the turbine housing is on the passenger side and the turbine housing is a giant casting were it starts at the passenger manifold and tubine housing and half of the down pipe is all on unit.
on
sorry to continue the off topic even more lol.
but did you guys running that intake under hood,see the test results on OBN latley (like yesterday-might be on first page still) where he saw about 70 degrees drawing in air from outside,and like 140 under the hood.cruising down the pike at 65 or so.
thats like 70 degree hotter air your putting into the engine.
try the ram air,or cowl induction Ronnie.
(nope its now on page two.its called: "Intake Air Temperature Experiment")
anyway,if your not signed up over there,a guy bought a digital temp gauge with appropriate sender,and ran tests while going down the road,and idle.long story shot,its hot under there,and the cooler and more dense the air,the better performance and fuel economy you'll get.
