I am thinking about adding some more lights to my f250 super duty and would like to get your thoughts (and hopefully pictures of yours mounted) before I bit the bullet..
What type of lights are you looking to add? I have two blue LED lights behind the grille (on a switch), some running lights under the radiator support, and the 3 light ID bar under the tailgate.
We do a lot of night driving on desolate roads. Roads where the suicidal animals roam... Usually with a trailer and/or heavy loads. Yeah, I got lights. Two sets of driving lights and a set of H/L beam 4x6 lights where the factory fog lights were. All on redneck fabbed brackets.
No photos, though.
I mounted 4 Hella 500s to the front of my truck. I made a bracket that protrudes through the grille. I know some people have put them behind the grille.
I installed the cab clearance lights on my truck not too long ago. The main thing to remember is to measure, measure, measure. After you do all of your measuring, you measure again. As long as you get your holes close to where they need to be, you will be fine. Good luck.
