front end swap
Old Nov 2, 2010 | 01:20 PM
jonnykford's Avatar
jonnykford
front end swap
im new here i have a 1984 f250 i want to make it a solid front axle. what axles will fit better? a 79 f350 or a 96 f350 axles
Old Nov 2, 2010 | 02:02 PM
Franklin2's Avatar
Franklin2
85.5 up are a bolt in. 79 requires some lift to clear the pumpkin, and they are hard to find in the Dana 60 version. All 85.5-up solid axles are Dana 60. Most 79 axles are Dana 44 axles.
Old Nov 2, 2010 | 02:53 PM
jonnykford's Avatar
jonnykford
so the 96 axles would bolt on?
Old Nov 2, 2010 | 06:08 PM
jrwhitmire's Avatar
jrwhitmire
You will need the springs, as F250's use a reverse arch, and the steering components, tie rods, drag link, etc. F350's also use a track bar, but some say they're not necessary unless you off-road or have it lifted.
Old Nov 2, 2010 | 06:23 PM
jonnykford's Avatar
jonnykford
its not my daily but when my powerstrokes down it gets used for work and thats alot of off road and bumps
mstng5point0
15
Feb 14, 2012 07:35 PM
Pigeon
Jun 10, 2007 09:09 AM
broncscott
Jan 16, 2007 04:12 PM
weldboy
May 4, 2006 12:01 PM
