Heat insulation coming down onto the turbo's and causing a fire
I'm kinda resurrecting an old thread here and am off topic, but what am I seeing there in the pic submitted by Longview1 where it appears there is a band clamp on the oil breather thing and the breather hose is removed from between the oil filler "thingy" to the air intake. sorry for such "technical jargon but cant think of official name for that. any rate...it appears the breather hose has been removed and clamped off?? what is benefit of that and how did you go about plugging that off? I looks like a bolt clamped in the intake connecfion..what did you do at the oil filler end?? route a hose down toward ground?
I heard about that from a diesel tech guy I talked to way back when I bought my truck.I didnt hear or read anything more about it and kinda forgot about it. Any special kind of heat resistant hose needed to vent downward with? the hose thats there is only a few inches long. How big of problem is the oil vapors goin back into intake?
Racor ccv filter is a nice set up....I've looked at them online several times. I went with a home made one...some 1 1/2" abs pipe, couple end caps, couple kitchen scrubbers and some 1" heater hose. Mounted it up front to the side of my intercooler. Not sure if this works as well as the Racor ccv filter mind you...however I drain a teaspoon of oil or so out every few months and have no oil residue in my upper cac pipe either. :-).
Some guys just vent to atmosphere, but vapours can be stinky to say the least. You can run it to the rear of the truck as well, but make extra sure there are no low spots in the hose as moisture will collect in there and reduce flow and increase crankcase pressure which is not a good thing.
The purpose of this mod is to keep as much oil as possible out of your intercooler. It will collect in there, coat the inside surfaces reducing efficiency of the intercooler. The oil can also gum up the turbos over time as well.
Hello I'm new here to the site and have a question and a little story of what happened to me. I've been looking here to see if anyone has had this problem? I bought my truck new and have been smelling what seem to be something burning but we could never find anything. This past summer we smelt it really bad I pulled over and this time noticed smoke coming out of the hood. I looked around and finally opened the hood slowly to make sure know flames. I then see my firewall insulation smoldering red almost fire I grab water bottles and put it out. So I finally get back home and talk to the service mangler at the ford dealer by my work and he said it wouldn't have ever caught fire should have left it and kept driving. So I checked on the internet to see some trucks have caught fire. I guess my main question here is I have bought the ford premium warranty and kept it on my truck since it was new, so is this something that should be covered by ford? Sorry to be so long winded, Thanks in advance for any help here... Steve
edtahaney
2015 - 2020 F150
10-24-2015 10:50 PM
