96 F250 Clutch problem
I take it you mean Power Stroke diesel with a 5 speed trans? If it is a 4 speed it would have to have had an older trans swapped in.
However the only adjustment might be on the master cyl pushrod. Look under the dash at the clutch pedal and look at the rod that goes from the pedal through the firewall to the master cyl, some were adjustable.
Hydraulic Clutch Troubleshooting .: Articles Here is a link to a good article on clutch linkage problems.
harleytn
03-17-2014 06:52 AM
Lumpy250
07-05-2006 01:24 AM
bill macparker
10-22-2004 01:23 AM
rafterjf250
01-17-2003 10:37 AM
